o2 sensor problem check engine light. (what can happen?)
Old Aug 23, 2008 | 04:33 PM
calvinhuh's Avatar
Default o2 sensor problem check engine light. (what can happen?)
well i found out im throwing a code for o2 sensor.
throwing a code something like po 318 or something.
seems like i might be having like a leak. from o2 sensor and the header.
couldnt tighten the o2 sensor all the way in. so i could be having alittle leak.
or the o2 sensor isnt working at all..
whats the worst thing that can happen to my car.?
a friend of mine was telling me. that its throwing a code cuase there is alittle bit of a leak. all its doing it running alittle rich and is using more fuel.
im trying to make money so i can buy the stock header and the new o2 sensor.
hopefully i can get thoes 2 things by next week or so. i dont like having CEL on when im driving.. drives me insane..
will my car be ok.?
Old Aug 23, 2008 | 04:51 PM
B_Real45's Avatar
You need to know what the code says exactly.. I'm not familiar with a P0318... a P0308 is a misfire code for cylinder #8 - so that shouldn't apply to you.
Your car should be under warranty - why not take it to the dealer??
Old Aug 23, 2008 | 04:54 PM
calvinhuh's Avatar
aftermarket header. ><
thats why hopefully it would be fine until i get the stock ones back.
with new o2 sensor..
Old Aug 23, 2008 | 05:51 PM
B_Real45's Avatar
It'll be fine if you don't drive it hard.
I was driving with a faulty O2 sensor for over a month.. it was showing a P0171 - which means System Lean Bank 1.
Old Aug 23, 2008 | 05:53 PM
calvinhuh's Avatar
what does that mean.?
how did u fix it.? oh man im hella scared about my car now.
Old Aug 23, 2008 | 06:09 PM
B_Real45's Avatar
What does it mean??
Ok.. like I said.. I was driving with a bad O2 sensor. My check engine light showed a code of P0171 - which means System Lean Bank 1... which means my the O2 sensor thinks the car is running lean.
I fixed it by taking it to the dealer because I'm under warranty.. but I could have fixed it myself by buying a new O2 sensor.
Just dont' drive it hard and you'll be fine.
Old Aug 23, 2008 | 06:13 PM
calvinhuh's Avatar
the thing is the CEL dissapeared
but last nite i was coming back home from freeway the CEL came back on again..
does it do that normally ? or did someone bad happen again.
like did some other code come up.?
were u able to drive around with that code po171?
im planning on goin to check my car with scanner again. just to make sure im not getting other codes..
Old Aug 23, 2008 | 06:16 PM
B_Real45's Avatar
Yes it comes and goes... the codes are timed by what Scion calls "Drive cycles".. if the light goes away, the code still exists, and is just hiding in the ECU.
Yes I was able to drive with my code. In fact the car drove fine - it was the CEL that was annoying to me.
Just drive it normally until you get the stock header on - then take it to the dealer.
Old Aug 23, 2008 | 06:18 PM
Mouse's Avatar
What you should do to put your mind at ease in the meantime is stop by any local autoparts store. Not sure what they have in CA but like a Checker, Advanced Autoparts, etc. They all have the OBDII code readers on hand and can check what the code actually means. The CEL generally needs to be tripped (on) to read it correctly. Then if it's minor you know you wont be damaging anything by driving it until you can get to the dealer. If you're running a racing header like I am... PM me back and I'll tell you how to fix the CEL for that situation.
Old Aug 24, 2008 | 02:43 AM
calvinhuh's Avatar
hew.. porblem solved.
apperantly
the thread for the o2 sensor was completly gone the sensor was almost out.
leaking like maddddd
it was surprise that i didnt melt anything.
bought new o2 sensor and all the CEL is gone
Old Aug 24, 2008 | 02:53 AM
B_Real45's Avatar
You need to reset the ECU... or the light will come back on.
Old Aug 24, 2008 | 06:33 PM
calvinhuh's Avatar
thanksss for the info
Old Aug 25, 2008 | 10:07 PM
calvinhuh's Avatar
oh man ur right my CEL did come back on
hopefully i just need to reset the ECU like u said.
can this be done with a scanner.??
Old Aug 25, 2008 | 11:03 PM
B_Real45's Avatar
The scanner is to clear the code.. do that.
Then you need to reset the ECU. Either pull the fuse for about 10 mins or just disconnect your battery for the same amount of time.
Old Aug 25, 2008 | 11:16 PM
deflaytedwayz1's Avatar
Mine came on but it was p0420 I think. Bank 2. Would that be the 02 by the cat? I'll have to crawl under there and check it out. I'm not under warranty either.
Old Aug 25, 2008 | 11:55 PM
calvinhuh's Avatar
isnt that just the code for having catless header? arent u using anti fouler on the s pipe ?
Old Aug 26, 2008 | 12:03 AM
The only engine mod I have is cai. The light came on 15,000 or so after that was installed so I'm pretty sure there is no relevance
Old Aug 26, 2008 | 04:58 AM
calvinhuh's Avatar
srry.. hmm then im not sure what the problem is for u.
back to me.
is it possible that im throwing the CEL for having aftermarket header.? again? even though i already have anti fouler on and everyting.
Old Aug 26, 2008 | 06:45 AM
tkevin07's Avatar
well if u run it for a while i kno the preludes burn their catalytic converters out if the o2 is bad lol so im sure it applies to scions too
