be careful painting your interior
Old Aug 26, 2008 | 03:27 PM
ERIK-TC's Avatar
Default be careful painting your interior
i botched up on some of the smaller pieces on my dash and in the shift area.
mainly just the heating/ac control ****, the shift bezel(grey Rectangle) and the actual shift plate.
100 bucks to replace all three.
I dont think i'll be trying this again. too much trouble if you F up
Old Aug 26, 2008 | 03:30 PM
SATownScion's Avatar
where are the pics? got a buddy that is going to paint his xb2 in a few days.
Old Aug 26, 2008 | 03:35 PM
ERIK-TC's Avatar
coming tonight when im home.
i wish i could get a clear temperature control know.
the stock blue and red leds or whatever are back there are bright as hell with the **** off at night.
Old Aug 26, 2008 | 03:49 PM
BlckdOutTC's Avatar
wat u mean u botched up?
Old Aug 26, 2008 | 05:07 PM
ERIK-TC's Avatar
like the paint didnt finish well even though i let it sit for 2 days and did about 8 coats, when i was putting the shift assembly back together the bezel around the shift panel scratched some of the paint of the visble front towards the engine, no way it can get all that paint off, and since it went down 8 layers of paint, getting it to look right with respraying is just not an option.
Old Aug 26, 2008 | 05:13 PM
captainlaziness's Avatar
Sand and repaint. It's pretty simple to fix.
Old Aug 26, 2008 | 05:26 PM
Nicobull's Avatar
^^ that he messed up/ damage
Old Aug 26, 2008 | 05:54 PM
yellowxhoodie's Avatar
x2. idk why youd buy new stuff.
either sand and repaint.
or
use paint thinner, clean, sand, repaint.
Old Aug 26, 2008 | 07:12 PM
yeldak's Avatar
8 coats????? That might have been the problem, if you sprayed those coats without proper flash time in between, the paint will look like straight butt... you should only have to spray 3 coats, 4 at max.
Old Aug 26, 2008 | 08:18 PM
ERIK-TC's Avatar
paint thinner warps plastic, essentially why i had to get a new bezel, let it sit in there for a few minutes and it was slightly warped to when it was put back on around the shift assembly, it didnt sit all the way against it, the bottom left corner was raised up
Old Aug 26, 2008 | 08:25 PM
sequel's Avatar
What about plastic acetone? PaintScratch.com has it, saved my butt a few times.
Old Aug 26, 2008 | 08:48 PM
prob. cuz you let it sit in there.
i dont think you wouldve had a problem if you just put it on a towel and lighty wiped the plastic.
Old Aug 26, 2008 | 10:13 PM
FLEA's Avatar
^ x2. Don't let it sit in there. Even if it does warp,it shapes back to it's original form in 24 hours. I'm doing BlckdOutTC's interior and I botched 2 pieces up the first time, just got to sand it down with 600 grit until all paint is removed, re-clean the surface, re-prep and spray the paint and clear all over again. I need to re-clear coat his, then it'll be ready to go. That's the easiest fix....or you can go buy new pieces which aren't cheap.
trikkonceptz
Jun 7, 2015 01:46 AM
mischman
May 30, 2015 01:22 PM
DaMax85
May 2, 2015 10:32 PM
mischadoll
Mar 9, 2015 05:48 AM
carid
Jan 30, 2015 02:23 PM
