MMW header + Greddy Ti-C...# of resonators?
Old Aug 29, 2008 | 11:09 PM
HaYnSktC's Avatar
Default MMW header + Greddy Ti-C...# of resonators?
hey guys im about to order an aero resonator but i wasnt sure if 1 would do it..
i dont have the header yet but i wanna have the things i need when i get the stuff done so i wont have to order and wait again hah
so my question pretty much is will the stock resonator + aero be good enough?
or should i just do 2 of the aeros?
i was also thinking about just doing like a 2.5 mid pipe but i wasnt 100% sure the size of the Ti-C...what you guys think? =)
Old Aug 30, 2008 | 12:35 AM
cmv138's Avatar
i would go with one if you going to run a stock mid pipe. if you are running the 2.5 mid then...one HF cat and one resonator.
Old Aug 30, 2008 | 03:26 PM
kalvinz61's Avatar
i have mmw header+spipe, stock mid pipe, greddy sp2 exhaust. i got a aero resonator put in between the cat and the stock resonator, its still kinda raspy but not as bad as before, but im still not liking it,
Old Aug 30, 2008 | 08:17 PM
HaYnSktC's Avatar
^so you saying 2 would make it better? =)
got a sound clip
whats the diff between the HF cat and a resonator?
will it also help with rasp? while being environmentally friendly haha
Old Aug 31, 2008 | 02:11 AM
kalvinz61's Avatar
well i guess you could do 2, i want a diff exhaust tho, not likign the SP2 with header
Old Aug 31, 2008 | 02:13 AM
BZinn1's Avatar
You are gonna need at least 24 inches of resonators,and it willstillhave some rasp.
Old Aug 31, 2008 | 02:45 AM
kalvinz61's Avatar
BZinn1 did you take out stock res and put in the bigger one, i just had them fit the aero between car and stock, maybe i should buy another 20" magnaflow res and take otu stock
Old Aug 31, 2008 | 03:55 AM
HaYnSktC's Avatar
i was thinking about doing the 2 aero resonators and a hi flow cat...would it fit?
Old Aug 31, 2008 | 06:39 AM
cmv138's Avatar
i have a concept G and a HF cat on the meagan mid pipe. still a little rasp. i think if i add a aero resonator it should do the job. the HF cat reduced alot of the rasp but i want to quite it down a little more now.
Old Aug 31, 2008 | 08:05 PM
BZinn1's Avatar
I had the stock resonator removed and 2 12" resonators welded into its place,I have room for one more if needed.I had the other option of going with a 22" resonator but decided that the pair of smaller ones gave me more actual sound dampening area.
The stock one does not seem to be very good for header applications the interior is not too good at slowing the flow and absorbing it.The Aeros are great at absorbing noise though.....a high flow cat with one of them would smooth the sound right out and if not you can go with 2.
Old Sep 1, 2008 | 07:14 AM
HaYnSktC's Avatar
alright cool thats good to know man..
so 2 aero resonators and another 12" hi flow would fit?
Old Sep 1, 2008 | 06:29 PM
BZinn1's Avatar
Yeah if they cut the stock res out and mount the Aeros in its spot you will have about 14" pipe between your res and the stock cat.........which gives you a bit of room for them to position it all.....stock cat is like 12" long so you have room to move stuff around.
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
prescottn
Sep 22, 2015 01:30 PM
prescottn
Sep 13, 2015 09:04 PM
