stage 3 clutch masters problem
Old Aug 30, 2008 | 09:30 PM
JINeration's Avatar
Default stage 3 clutch masters problem
Hello my fellow scion tuners I have a problem and not sure if I can fix it or not. Well I have installed a stage 3 clutch from Clutchmasters and it works fine and everything is just that my clutch pedal or the clutch master cylinder doesn’t create enough pressure to engage the disk until I pump it a few times is there a way to make the cylinder stronger or is there a aftermarket one that I can buy to make more pressure
someone PLEASE help me!
oh i forgot to add that there is BEARLY any play so like litterally right when i release the pedal the clutch is released
Old Aug 31, 2008 | 03:23 AM
unxpectederror's Avatar
did you bleed it properly?
Old Aug 31, 2008 | 03:39 AM
Ace83's Avatar
Ronin Scion
x2.. something is wrong there, i didnt have problem with the pressure plate on my stage 4 even the pedal feel and deepness is almost like stock
Old Aug 31, 2008 | 03:46 AM
JINeration's Avatar
okay ill try that but why would i need to bleed it...sorry if im like asking such a stupid question we never opend up the system where air or nethign could get in
Old Aug 31, 2008 | 03:48 AM
Ace83's Avatar
Ronin Scion
i dont remember mine being bleeded, not sure but if the problem is not having enough pressure to push the pressure plate, then the problem might be in your clutch line
Old Aug 31, 2008 | 04:05 AM
JINeration's Avatar
how would i fix that? and which line? we figues that maybe i would need a aftermarket mastercylinger so it can creat more pressure but i will try to bleed it tomorrow .... if the hurricane doesnt ruin my day lol
Old Aug 31, 2008 | 04:17 AM
toyota_scion_tc's Avatar
Definitely bleed it first at the slave cylinder.
Old Aug 31, 2008 | 04:31 AM
JINeration's Avatar
isnt that the only place to bleed the clutch lines
Old Aug 31, 2008 | 04:57 AM
The only correct way of doing it, there are other ways of doing it.
Old Aug 31, 2008 | 04:58 AM
JINeration's Avatar
ic ic thanks for the info guys i will try bleeding it tomorrow now if you have anymore idea please let me know cause im not 100% sure that bleeding it will help since i didnt open up the system
Dapitt84
Mar 4, 2015 02:03 AM
2012TC
Feb 17, 2015 08:41 PM
Ksn
Feb 4, 2015 02:10 AM
BrokenTC2
Jan 27, 2015 03:32 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
