sigh.....
Old Sep 2, 2008 | 11:08 PM
firesquare's Avatar
Default sigh.....
well i've been lowered for over a year now on S-techs springs and OTG 10mm spacers rolling on sport max 501's 15X8 195/50R15's
now i use to have Falken's on the car and now i have some Federal tires on there. they don't stretch like the falkens do.
my problem is after i switched the falkens to the Federals i scrape the tire on the RR very very bad. it never did it with the falkens before since the tire was stretched. the RR also looked and measured like a 1/8 to a 1/3 inch lover then the rest of the car. i swapped the springs around and changed the shock for a brand new Toyota one (40 bucks wasted) and im still scraping. nothing looks bent but i don't know what to do since that side was always that low. should i try new teins or what? is it the OTG's causing a problem causing it to sit lower then the other side. i would love to sit lower with some Tanabes but really want a stiffer spring. Teins are way WAY too soft.
are the girls i get together with too fat for my ride? it sucks i can only carry me and my one year old around town :-P cant even let my 130 lb fiance ride in it. :-P. i weigh about 135 myself.
ill try and get some pics up later. all i have is my dinky 3 year old camera phone
Old Sep 2, 2008 | 11:14 PM
Metro273's Avatar
I'm having a similar problem but with my Tein H techs! I get 2 people in the backseat and the rear drops to where it's almost touching the tires...
I think these Teins suck!!! I'll probably switch them out next spring!
Old Sep 2, 2008 | 11:20 PM
Black_Sheep_xB's Avatar
hmm.. only since the impact? is the spring stil in the upper and lower perches correctly? hard to say whats up...
Old Sep 3, 2008 | 01:20 AM
burstaneurysm's Avatar
I really think the Teins are super soft. The back end of my car doesn't sag nearly as low on the DF210s as it did on H.Techs.
Old Sep 3, 2008 | 03:12 AM
firesquare's Avatar
the only real deal is that its only one corner of the car and i already swapped the springs so i dunno. i never hit anything and everything seems to be in order.even with the stock springs in the car the RR sits a tad lower still
Old Sep 3, 2008 | 04:56 AM
Spider13's Avatar
It's not lower on that corner. The axle isn't center, more then likely its rubbing the fender lip. Roll the fender and you aught to be alright.
BTW with mine on Skunk Springs 2 adults in the back drags the muffler on the ground, on every bump.
Old Sep 3, 2008 | 01:49 PM
yeah.. Dragging/Rubbing ='s Common occurance on the box
Fender Roll FTW
Old Sep 3, 2008 | 02:44 PM
swartzautoman's Avatar
ive got 16x8 with 15 offset and 195/50/16
i had to roll the fenders and run -3 camber to get mine to stop rubbing.
mine seem to sit lower on the passenger side.
ive mesured from the top of the wheel well to the ground so im sure its not my axle.
ive checked between my lower perch and my ajustment collars and thet both ends of the springs are seated right, ive also made sure the tops of the shocks are tight.
everything checks out.
the only thing i can figure is that one spring is just setled more then the other.
Old Sep 4, 2008 | 04:04 AM
firesquare's Avatar
i got mine used with about 5K on them. i do a good amount of driving and i have a lot of chunky girls that ride with me. mostly cuse im their pimp.
how do you "roll" a fender. illl run a search on it after i post this but i hit it with a hammer and it help slightly but not too much.
should i just cut the fender? i have bBist flares bolted to the car
Old Sep 4, 2008 | 01:05 PM
well, ive only got one chunky girl and she is my queen.
don't use a hammer, you will be sorry you did.
this is the best way to do it.
http://cgi.ebay.com/Eastwood-Fender-...d=p3286.c0.m14
after you are done with the tool, just turn around and sell it, thats what i did and i only lost $40 out of the deal.
here is me after rolling the fenders and with -3 camber, me and my wife and a bunch of stuff in the back.
ive got Tein SS coilovers. the front springs are 220 PPI so they realy don't move that much, buck the back springs are 180 PPI just like the s-techs so the back still squats quite a bit when ive got stuff in the back.
i guess it would be equill to a few chunky girls back there.
i would like to get some stronger springs in the back so it doesn't move around as much.
Old Sep 4, 2008 | 10:30 PM
firesquare's Avatar
thanks for the link. i may just have to run some stiff spring rates too. or find me tires that are stretchable like my old Ziex 512's
Old Sep 5, 2008 | 01:25 AM
ive got 195/50/16 912 falkens, they strech nice + you can rotate them because they'r not directional
Old Sep 5, 2008 | 01:58 AM
firesquare's Avatar
did they replace the 512's with those because they discontinued those from what the tire place said
Old Sep 5, 2008 | 03:18 PM
im not sure
Trivecta
Scion tC 1G ICE & Interior
18
Aug 29, 2008 04:04 PM
evil_tt
Sep 21, 2006 07:01 PM
HKSpeed
Scion tC 1G Wheel & Tire
25
Jun 15, 2006 12:50 PM
