Looking to get your box stiff? Look no more!
Old Sep 3, 2008 | 02:55 PM
paul_dezod's Avatar
Scionetics
KAD
Default Looking to get your box stiff? Look no more!
I love coming into threads with fun punch lines. Anyway, just as an FYI, we have the entire xB1 set of bushings in stock and ready to ship. Black only though ladies and gents!
http://www.dezod.com/pd-energy-suspensions-rear.cfm
http://www.dezod.com/pd-energy-suspensions.cfm
http://www.dezod.com/pd-energy-suspensions-front.cfm
Enjoy! HUGE difference and response from a CHEAP mod.
Old Sep 3, 2008 | 08:12 PM
Romanova's Avatar
You have pictures for reference as to where the first two sets go? Is a press required to get the old bushings out? These are poly right?
Old Sep 3, 2008 | 08:14 PM
paul_dezod's Avatar
Scionetics
KAD
All of the parts are poly. The first set for the rear trailing arm, and the second set is the front control arm set.
Old Sep 3, 2008 | 08:31 PM
Romanova's Avatar
Is a press required to do any of them?
Old Sep 3, 2008 | 08:39 PM
paul_dezod's Avatar
Scionetics
KAD
May be needed for the control arm ones, but that is about it.
Old Sep 11, 2008 | 04:29 AM
bB384's Avatar
IV ACE
Are those the only bushings Energy Suspension made for the xA/xB? I thought they were going to make motor mount inserts, and rack & pinion bushings also.
Old Sep 11, 2008 | 01:26 PM
paul_dezod's Avatar
Scionetics
KAD
They did also make motor mounts.
http://www.dezod.com/pd-energy.cfm
Old Sep 11, 2008 | 11:59 PM
Bdiddy's Avatar
The front sway bushing/endlink set fits the xa as well?
Old Sep 12, 2008 | 01:29 PM
paul_dezod's Avatar
Scionetics
KAD
I have not gotten confirmation of this.
Old Sep 18, 2008 | 05:55 PM
captdownshift's Avatar
Strictly Scionized
made? did energy suspension stop making scion stuff?
Old Sep 18, 2008 | 06:04 PM
paul_dezod's Avatar
Scionetics
KAD
No. They are still producing tons of Scion stuff.
They did not however confirm fitment to the xA from the xB1 bushings
Old Sep 18, 2008 | 07:13 PM
Strictly Scionized
ok good, i was getting sccccared, thinking damn first perrin now energy
Old Sep 24, 2008 | 05:00 PM
DJ_SpaRky's Avatar
Do you have installation instructions?
BTW, the swaybar one will fit the xA, because the swaybar and it's mounts are the same, I have installed endlink kits on both, the $14 ones
Old Sep 24, 2008 | 11:44 PM
JSosa's Avatar
so the bushings fit an xA?? All of them, even engine??
Old Sep 25, 2008 | 03:36 AM
bB384's Avatar
IV ACE
This kit fits both the xA and 1st gen. xB. Both use the same motor mounts, sway bar endlinks (I'm not sure about the sway bar bushings itself, as the diamater may be different, but the endlinks have the same OEM part numbers). The torsion beam, control arm, and rack and pinion bushings are also the same.
Old Oct 23, 2008 | 05:37 AM
bB2NER's Avatar
Music City Scions
You can upgrade the inner ones when the stock ones wear out (about 100K). The outter ones are like 25 bucks at Autozone and are red poly.
Old Nov 21, 2008 | 10:59 PM
ryuji16's Avatar
how easy of a DIYer are these? lets say, in comparison to installing a set of coilovers (the extent of my experience thus far)
Old Nov 24, 2008 | 06:55 PM
L33TFooMaster's Avatar
Default Re: Looking to get your box stiff? Look no more!
I hate exposing how much of a n00b I am when it comes to suspension stuff, but this is all I recognize. I know what they are and where they go as I've replaced them on a previous car of mine but that's it. I don't know what to call them and I don't recognize the other images though I'm sure they're basically the same thing, but for the rear?
I'd like to learn more about suspension stuff, it's really a big weak point for me. Are these in any way better than the stock setup? Or are they basically replacement parts? If they're better could someone explain how?
Old Nov 25, 2008 | 05:09 PM
bump.
Old Nov 25, 2008 | 05:20 PM
paul_dezod's Avatar
Scionetics
KAD
They are called bushings. Standard bushings are made from rubber, which is quite forgiving and can easily flex under cornering and aggressive driving. These are made from polyurethane, which is a more aggressive material which does not flex or bow under hard driving, thus creating a more rigid aggressive driving experience more like that of a track car.
These are full stock replacements sir.
