anybody running 225/45/18 on their xb?
Old Sep 7, 2008 | 06:54 PM
ezazzmark's Avatar
Default anybody running 225/45/18 on their xb?
i did search and couldnt find anything.. anybody has this setup and also what offset are you running? pics if you have it.. thanks..
Old Sep 7, 2008 | 07:44 PM
Sciond's Avatar
moved to correct area
Old Sep 8, 2008 | 08:15 PM
jdl1681's Avatar
225/45/18 will rub all around and unless your on stock springs which even then odds are will rub. Also you will be massively over sized and the speedo will be off over 10 mph. I ran 225/40s at one point and they rubbed at full lock
Old Sep 8, 2008 | 08:20 PM
ezazzmark's Avatar
thanks for the reply.. so 225/45s will rub all around.. Its on stock springs.. and you said 225/40 was okay but rubbed at full lock? how about the rear? how close did the tires get to the wheel well? what offset were the rims that you them on?
Old Sep 8, 2008 | 08:35 PM
jdl1681's Avatar
I was running a 42 offset wheel 18x7.5. I was finding that the wheel was rubbing in the front on the plastic pieces at full left and right lock. Now this was with a drop on trd springs so with stock you may have no issues. The rear I war really close to the sub cross frame with the inside of the tire but never had any rubbing
Old Sep 8, 2008 | 08:42 PM
ezazzmark's Avatar
o ok.. cool.. thanks for the info..
k1114
43
Mar 1, 2023 03:08 AM
jthistle
9
Mar 11, 2016 03:12 PM
kahsperr
Regional - Pacific South
Mar 26, 2015 06:25 PM
DDonovan
Regional - Canada
Mar 23, 2015 08:51 PM
cid_mcdp
Jan 5, 2015 02:45 PM
