Will this work?
Old Sep 9, 2008 | 11:18 PM
KillaSpiceTSW's Avatar
Default Will this work?
I was wondering if you could use a Fidanza or CC Aluminum Light Flywheel with a stock Clutch setup. Also I was wondering if anyone has heard of F1 Racing. I checked ebay and saw this, tell me what you think. http://cgi.ebay.com/ebaymotors/F1-RA...spagenameZWDVW
Its pretty cheap only 480 shipped and that is for the F1 Racing Clutch and Fidanza Light Flywheel. Thanks guys.
Old Sep 9, 2008 | 11:56 PM
B_Real45's Avatar
looks like a SPEC clutch..
Old Sep 10, 2008 | 12:01 AM
ippskidder's Avatar
1UP Crew
Yea you could use it.
Just FYI, the lighter the flywheel, the higher you have to rev to launch.
But once your moving, it feels great. ^^
Old Sep 10, 2008 | 12:03 AM
ippskidder's Avatar
1UP Crew
Oh and, as far as clutch, I usually stick to ACT or Competition Clutch.
Preferably CC. But thats just my .02 cents
Old Sep 10, 2008 | 12:12 AM
Yeah I was thinking about getting the CC Stage 2 and a flywheel. Whats better in your opinion CC or Fidanza flywheel. Or let me rephrase, what has been known to be more reliable, LOL. And on another note what is a SPEC clutch.
Old Sep 10, 2008 | 01:33 AM
B_Real45's Avatar
SPEC is just another brand.. I'm not saying that what was posted IS a SPEC.. it just looks like one.
As for the flywheels, I doubt you can go wrong with either. I personally have the CC 9lb Flywheel - it's Forged Steel instead of Aluminum like the Fidanza.
Old Sep 10, 2008 | 01:53 AM
ippskidder's Avatar
1UP Crew
x2
as b_real45 said.
the fidanza is aluminum, the CC is steel.
I have the CC, and my friend has the Fidanza. They feel pretty much the same. Both you have to rev higher, lol.
I just got the CC because its steel instead of aluminum.
But not sure if that makes a difference in the long run.
Theoretically it should last longer. But not sure
Old Sep 10, 2008 | 02:05 AM
Sweetness. Does our stock flywheel really weight 31 pounds, I found a site for the stock flywheel and it weighed 31 pounds and was 400 dollars. Holy jumping f@cken jesus.
Old Sep 10, 2008 | 02:10 AM
ippskidder's Avatar
1UP Crew
You get better launches with a heavier flyhweel.
A friend of mine has a 12lb flywheel I believe. I'm sure he can launch better than I can with my 9lb.
But anything is better than the heavy a s s stock flywheel =)
Old Sep 10, 2008 | 02:42 AM
davedavetC's Avatar
Get the Competition Stage 2 Clutch and the Competition Clutch 12lb flywheel. i just got my car back and its a great combo. smooth like stock but grabs like a ****... oh and the flywheel is great, revs so much better then before.
Old Sep 10, 2008 | 03:06 AM
Hey dave, are you trying to imply just to get CC Flywheel or that the 12lb flywheel is better then the 9lb or both. And whats the big difference between the 9 and 12 lb flywheel besides the 3 lbs.
Old Sep 10, 2008 | 03:17 AM
davedavetC's Avatar
get teh CC flywheel, i have the 12lb and i love it
Old Sep 10, 2008 | 03:20 AM
B_Real45's Avatar
I'm not sure if you'll feel much of a difference..
I have the 9lb and I love mine.. so who's right?
The only thing to do is pick one.. you'll love either one.
Old Sep 10, 2008 | 04:21 AM
BuddhasTC's Avatar
i have the fidanza with stock clutch...works fine...honestly though it's not that big of a difference...maybe because i'm on stock clutch...but you do notice it a little
Old Sep 10, 2008 | 04:58 AM
bmph8ter's Avatar
Your stock clutch will work. Launches will be a bit tougher till you get the hang of it. The freer revving is nice though.
Old Sep 10, 2008 | 07:03 AM
ippskidder's Avatar
1UP Crew
The 3lbs is noticeable, when you try to launch from a dig.
Once you get going though, the 9lbs is better.
But keep in mind. The 9lb speeds up faster, and also slows down faster, because of inertia.
Where as the 12lb speeds up slower, but also slows down slower.
But most of this is negligible, compared to the complete build of the car. So if I confused you i'm sorry >.<
Basically, if you don't mind revving higher to get going, then get the 9lbs. On the freeway it feellssss great.
If you want better numbers at a drag strip then get the 12lb.
Fidanza and CC, get which ever one you like. Both are reputable. I also think both companies carry both versions of 9lbs and 12lbs.
Old Sep 10, 2008 | 02:56 PM
e246's Avatar
seems like a good mod to get while i save for f/i.. I was wondering whats the stock flywheel weight.. And the 12 lb will still add faster accleration? I gues ill get the clutch to, prolly stage 2 or 3 somthing...
Old Sep 10, 2008 | 03:31 PM
ippskidder's Avatar
1UP Crew
I'm pretty sure the stock flywheel weight more than 20lbs, maybe even 30lbs.
When I compared the stock flyhwheel to the aftermarket version.
My jaw dropped, lmao.
Its THAT big of a difference.
Yea, you will have better acceleration with the 12lb than with a 9lb, from a dig.
But, once your in motion, the 9lb is more preferable.
If your gonna get clutch kit, get a CC. I've compared my ACT to my friend's CC. The CC seems sturdier, that might explain why its a little bit more expensive too =P
But if your short on cash, just get the ACT clutch kit. I never had any problem with it.
Old Sep 10, 2008 | 04:38 PM
e246's Avatar
OK ill get the 12 pound.. Ya that is a big weight difference.. It doesnt hurt the off line accle too much with the 12 does it.. we have good power there.. also how much harder would it be to take off..
Old Sep 10, 2008 | 05:08 PM
ippskidder's Avatar
1UP Crew
It just takes some getting used too. At first you'll be like WTF lol.
But the car will rev considerably faster, which is a major plus.
I say go for the 12lb ^^
xBSciontist
Jun 18, 2019 03:06 PM
missing_image
Feb 7, 2015 07:18 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
