Attention Inferno Underbody Kit Owners!
Old Sep 14, 2008 | 10:21 PM
STNC's Avatar
Default Attention Inferno Underbody Kit Owners!
Ok,
I have an underbody kit with way to many wires and way to many tubes...It has an audio in, which is a tiny little plug, (Smaller than a 3.5) that splits to a white (Positive) and a Black (Negative). It told me to tap them to the + (Pink) and - (Violet) wires from the speakers. I did that, and now, whenever I put the plug close to the hole on the controller, the subs pulse at full volume. I'm using a line out converter as I am still on the stock hu....but yeah...Anyone else have this problem?
*Edit*
For the inferno Underbody Kit Users, what speaker lines did you tap? Do any of you use a line out converters?
Old Sep 15, 2008 | 01:44 AM
STNC's Avatar
If i run the audio wire on rear negative and positives would that fix it?
Old Sep 15, 2008 | 11:37 PM
iaminsider's Avatar
Have you tried doing this with everything turned off? It sounds like your system and underbodies are turned on when you are trying to plug it in.
Old Sep 15, 2008 | 11:38 PM
STNC's Avatar
i will try again tonight
Old Sep 16, 2008 | 12:37 AM
STNC's Avatar
It still does it, I'm gonna try and tap the rear speakers tomorrow
Old Sep 21, 2008 | 06:33 PM
STNC's Avatar
Ok, i tapped the rear left, and it didn't pulse except for a few times...
Inferno Owners...How did you do it? Any of you guys use a line out converter?
Old Sep 22, 2008 | 02:57 AM
Dandaman3201's Avatar
mine made a loud noise everytime I tried to change colors when on audio mode. I really just stopped using it because it really doesnt pick it up that great anyway and I had this problem. But I didnt use a line out converter so really cant help you too much on that. I would go post this on oznium.com they helped we with angel eye problems im sure they can help you with this.
Old Sep 22, 2008 | 02:58 AM
STNC's Avatar
hmmmm
I experience the same thing with the loud noise! So i guess its not the line out
NonStopTuning
Jan 20, 2015 05:20 AM
evolving_machine
Jan 13, 2015 08:04 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
minter66
Dec 15, 2014 01:45 PM
cb900f2
Scion tC 2G Aero & Exterior
Dec 14, 2014 10:46 PM
