brownboy
12-19-2004, 03:00 AM
I finally finished a three week adventure building this fiberglass subwoofer enclosure. This is a second generation (my first attempt was horrid-looking). I wanted something that would would be extremely low profile (so that it would be hidden from view), so I used a Pioneer TS-SW124D (requires a mere 3-3/8" mounting depth).
Because I did not want to do the customary tape/foil the car interior and fiberglass, I decided to use the stock styrofoam storage bin as a plug in order to develop a mold. I masking taped it, oiled it, and then used plaster of paris and cotton strips to build the mold. This is how the mold turned out:
http://www2.arkansas.net/~barcenilla/subwoofer/1.jpg
http://www2.arkansas.net/~barcenilla/subwoofer/2.jpg
In the first picture, you can see the MDF ring that I made to allow recessing of the subwoofer flange. I also glued in some T-nuts so that machine screws could be used to fasten the sub.
After the mold was made, I simply laid the fiberglass within the mold to the desired thickness. After it dried, I sacrificed the mold to release the fiberglass shell. For the top, I laid fiberglass on a foiled piece of MDF and incorporated the MDF ring after a couple of layers. This allowed for fiberglassing the entire bottom piece of the MDF ring so that an interference connection (rather than the typical "glued" connection) could be made. After that dried, I laid the top piece onto the main body shell, trimmed it, and then fiberglassed the two together. Here are the results (pictures were taken after painting the MDF rings):
http://www2.arkansas.net/~barcenilla/subwoofer/3.jpg
http://www2.arkansas.net/~barcenilla/subwoofer/4.jpg
I also created an MDF deck to replace the stock pieces for the rear. This would allow for a clean one-piece look that was vibration-free. I was also able to cut out a section to act as a grille (perforated aluminum sheet metal hidden beneath the carpet). This is how the MDF deck turned out:
http://www2.arkansas.net/~barcenilla/subwoofer/5.jpg
The following pictures show the finished product carpeted and installed. Note that you can see the aluminum grille beneath the MDF deck in one of the pictures:
http://www2.arkansas.net/~barcenilla/subwoofer/6.jpg
http://www2.arkansas.net/~barcenilla/subwoofer/7.jpg
