E-Brake Light Comes On At High RPMs
yeah so as the title says
when i take off from a light and i dont shift till about 5k
the ebrake light comes on
adn its happened at 4k too
also happens in 2nd gear
any body know y this is happening?
-EAmon
ps
yes i did search but found nothing
-EAmon
ps
Check the switch for it that is connected to the shifter.
When you put the TRD quickshifter in you may have messedup the adjustment causing it toturn on the e-brake light due to wiggling around when you drive.
i didnt put it on
it was on my car when i ordered it
and it never had sone that in teh 2 years my mom drove it
and it just started happening about a week ago
Originally Posted by pctD
You need more brake fluid.
^^^Speaking like a tech here, the squeal that some of you are hearing is most likely coming from the rust ridges that are developing on the inside of the front rotors. When you brake, the lower portion of the pad "rides" along this rust ridge and causes the squeak or squealing some of you hear. Very common, especially cars that are hardly driven "hard" or sit around.
Next time when you do your brakes, check the inside of the rotors and you'll see it. This is why the "stealership" charges what they charge, to resurface the rotors...
Originally Posted by Metro273
^^^25K and already need pads? Wow!
I have 39K and I still don't need them...
and i uhhhh drive my car..
Your clutch uses the same brake fluid.
Most brakes make noises when ridden or after a rain storm. When you hear a searing rail car like squeal, thats when they need replacing. They have a metal tab off to the side to hit the rotor and make this noise to let peeps know to replace the brakes.
