disconnecting the battery before I install a head unit?
Old Dec 19, 2004 | 03:59 PM
reagan9000's Avatar
Default disconnecting the battery before I install a head unit?
hi - Do I need to disconnect the battery before installing a new head unit? Or is it good enough to just have the car turned off?
Old Dec 19, 2004 | 04:00 PM
tbone587's Avatar
thats a good question I would also like to know... I would say probably not because you really arent touching any hot wires.. But im not 100% sure.
Old Dec 19, 2004 | 04:37 PM
SWF_05_tC's Avatar
You don't need to disconnect the battery. It's always a good idea, but for a simple HU install, it's not all that necessary IF you know what you're doing (ie: don't cross positives and negatives). For simple plug and play harnesses I wouldn't even think twice about it, can't screw anything up that way.
Old Dec 19, 2004 | 04:40 PM
Munch's Avatar
If this is your first time installing a head unit, then I would. If you've done this before , then don't worry about it. It's not needed.
Old Dec 19, 2004 | 04:54 PM
oneslowxa's Avatar
if you are using a harness.. connect the car harness to the radio harness first, then plug it into the car... there is almost no chance of messing it up... but if you are even slightly scared of popping a fuse then disconnect the battery...
Old Dec 19, 2004 | 05:09 PM
dgHotLava's Avatar
as always good advice...
Old Dec 19, 2004 | 05:31 PM
Munch's Avatar
Thanks man I try
Old Dec 19, 2004 | 06:15 PM
Max2k's Avatar
Can't hurt.
wiltonhall
Jun 23, 2025 10:09 PM
clickclickw00t
Feb 18, 2015 08:57 PM
NewBox06
Feb 3, 2015 04:02 AM
billzor
Scion tC 2G ICE & Interior
Jan 17, 2015 12:38 PM
lunchbx05
Dec 11, 2014 06:13 PM
