Those with BB GT30R
How do you guys like their spool. Im using a el top mount, the turbo is a 56trim .63 turbine and .60 compressor. Those who have this turbo with similar specs can, you tell me how your spool is.. thanks..
reaching full boost varies depending on set psi and gear.. it will reach 7psi before 4K.. dyno numbers werent good but its coz im dumb and had my car tuned with tons of issues lol
Originally Posted by B_Real45
Fix all leaks first..
Originally Posted by deathbyc4
Mine is 3431RE full boost around 3500 rpm @ 10 psi. 315whp 321 wtq.
mikescion-What trim and A/R are you 6031RS is your motor built. Or stock. Im only looking to hit 350hp-375hp high boost.
deathbyc4-Same questions, what trim was your turbo and a/r.
Im trying to decide which one i Want. And, also are you two guys turbos 4 bolt.. My dp is a 4 bolt.
I'm not sure if Mikescion is using the 6031RS...
But the 6031RS uses just about the equivalent compressor wheel as a 60-1. The exhaust wheel is equivalent to the Stage III.. so I highly doubt you will get 20psi at 3300rpm on our motor without heavy other mods.
It's pretty much a T4/T3 60-1 with a Stage III exhaust wheel.. and the RS comes with a larger compressor cover with a 4" inlet.
pure sex. spools so stupidly fast.
