30,000 Maintenance
Old Sep 25, 2008 | 02:20 PM
Mr_Meaty's Avatar
Default 30,000 Maintenance
I'm due for my 30,000 maint but I don't think the shop is going to cover this stuff on my car, or it will cost extra, or I can do it myself, but there are a couple things I'm not sure about.
Here is the list of what is covered in the 30,000 mile maintenance from the dealership:
Factory Maintenance: Replace engine oil and oil filter (1)
Rotate tires
Replace engine air filter
Replace spark plugs (xA and xB) (3)
Tighten drive shaft bolt
Replace manual transmission oil
Replace auto trans fluid (Type IV)
Replace front differential oil
Replace cabin A/C filter (xA & xB) Additional $49.95
Tighten nuts and bolts on chasis
-Inspect brake linings/drums and brake pads/discs (4)
-Inspect drive shaft boots
-Inspect engine coolant
-Inspect exhaust pipes and mountings
-Inspect ball joints and dust covers
-Inspect fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
-Inspect fuel tank cap gasket
-Inspect radiator core and condenser
-Inspect steering gear box
-Inspect steering linkage and boots
-Inspect all fluid levels
-Adjust tire pressure
-Inspect brake lines and hoses
OK, now I'm sure theyd charge me extra for full synthetic, my air filter is reusable, and they probably don't even cary 2-step colder plugs.
The rest of the stuff, I'm not sure of.
Where is the Drive Shaft Bolt?
How do I replace the Manual Transmition Fluid?
And how do I replace the Front Differential Oil? (or is this only if I have the LSD?)
Old Sep 25, 2008 | 02:26 PM
Ace83's Avatar
Ronin Scion
meaty driveshaft boot is that boot one your axle, check for leaks, manual tranny fluid there's a DIY here search for redline MT90, front differential oil not sure where is that but i thought its covered by the tranny fluid, but we have a differential too so im pretty sure its needed
Old Sep 25, 2008 | 03:03 PM
GammaTNT's Avatar
that reminded me , i have to do change my tranny fluid again.
Old Sep 26, 2008 | 04:27 AM
Mr_Meaty's Avatar
it says driveshaft bolt, not boot. Got a pic? or a diagram?
Old Sep 26, 2008 | 07:23 AM
Coolwaterz's Avatar
drive shaft bolt? isnt that for rear wheel drive or all wheel drive cars? and im pretty sure all scions are FWD...
dont maintain...upgrade.
Old Sep 26, 2008 | 12:52 PM
Ace83's Avatar
Ronin Scion
i believe its the axle nut that you will check that its tight
Old Sep 26, 2008 | 01:20 PM
vettereddie's Avatar
Wow, on the xB the drive axle nut has a detent in it that lines up with a notch in the shaft, makes it pretty much impossible to loosen but has the downside of destroying the threads if you do ever need to remove it (ask me how I know).
Old Sep 26, 2008 | 01:25 PM
Ace83's Avatar
Ronin Scion
^^ thats normal, its same as the tc.. thats done on purpose to lock it. you have to hammer it to unlock it
Old Sep 26, 2008 | 01:28 PM
cessblood's Avatar
Thanx for the reminder Meaty
Old Dec 1, 2008 | 07:22 PM
jojohenn148's Avatar
Default Where is drive shaft bolt located?
The maintenance guide says to tighten drive shaft bolt. Where is the drive shaft bolt located?
Old Dec 1, 2008 | 10:45 PM
jct's Avatar
jct
there is none
Old Dec 3, 2008 | 01:53 PM
Mr_Meaty's Avatar
if there is no driveshaft bolt, why is it listed as a maintenece item in the manual?
pro710
Dec 27, 2023 03:34 PM
Threequalseven
Aug 26, 2015 04:24 PM
bmxScion
Jul 23, 2015 12:07 AM
michaelclld
Jul 16, 2015 04:32 AM
stenger
Jul 15, 2015 01:03 AM
