06.5 Taillight Removal....
Old Sep 25, 2008 | 10:14 PM
Sunny's Avatar
Default 06.5 Taillight Removal....
WTF? with out cutting plastic or sheetmetal or the use of mirrors, how do you get them off?
And yes, i have looked in the tech forum, they make it look easy. Remove the access cover pop out 2 10mm bolts unclip the plug and tada.
I can feel around and get the bottom bolt but the top one seems impossible to access, also whats the clip look like i am trying to unplug?
Old Sep 25, 2008 | 10:50 PM
kewlbox's Avatar
Keep trying the other one it is posssible, but also is a very tight area.
You will see the plug either when you pull the taillights out or inside the access cover. best to see what the plug is when you get the taillights out.
Old Sep 25, 2008 | 11:24 PM
kunfuzion's Avatar
it is easy. the plug is located on the back of the center light socket (if you're running the OE lights). just depress the clip and pull away. then take out the 2 10mm nuts and you're done.
Old Sep 25, 2008 | 11:37 PM
peteski's Avatar
just don't drop any of those nuts. They'll forever end up in a "black hole"
Old Sep 26, 2008 | 02:42 AM
evosky's Avatar
just be patient. there are no shortcuts. take your time. it will come out.
Old Sep 26, 2008 | 03:33 AM
sdsnybny's Avatar
stuff a towel in the bottom so if you drop your nuts you can find them without cursing
it helps to shine a light in there to get a good look before starting,
yeah and its a _____ with big hands i used a 1/4 socket set with an universal adapter
to get them off
If you have the TYC's that were an option there will be 3 wires to unhook when they install them there is a harness adapter added to stock socket to get them to work. It helps to get the nuts off if you push in on the tails (against the seal) to help relieve tension
Good luck
Old Sep 26, 2008 | 11:42 AM
Sunny's Avatar
so fk it. I just ordered vinyl overlays
Old Sep 26, 2008 | 02:27 PM
1epoXyBox's Avatar
Not sure if this helps or not, but look here:
https://www.scionlife.com/forums/vie...732&highlight=
Old Sep 26, 2008 | 03:08 PM
burstaneurysm's Avatar
Yea, access back there sucks.
The harness is in the center, you can follow the wires to it.
I find that it's easier to place the socket/short extension on the bolt first, and then attach the ratchet.
I hate changing tails out.
Old Sep 26, 2008 | 05:18 PM
evosky's Avatar
i always get the ratchet in there to get the thing going for a few turns and then do the rest by hand ...
Btp907
Sep 11, 2015 11:46 PM
blue_xB_23
Mar 20, 2015 07:39 PM
Godfryness
Jan 2, 2015 11:18 PM
