Gauge Cluster LED/Vinyl/Reverse Help
Old Sep 30, 2008 | 04:26 AM
XSNiper's Avatar
Default Gauge Cluster LED/Vinyl/Reverse Help
Does anybody know how to install the translucent vinyl and reverse LCD items on Garage1217 for the gauge cluster?
This is the style I'm going for. I made this in photoshop so I didn't reverse the LCD in this pic.
Old Sep 30, 2008 | 04:45 AM
SquallLHeart's Avatar
yes..
place vinyl on the back of the gaugeface where needed..
and remove stock lcd filter... install new one.
Old Sep 30, 2008 | 05:09 AM
O5_TRD_tC's Avatar
something like this...
Old Sep 30, 2008 | 03:15 PM
XSNiper's Avatar
Ok, so how would you get the white numbers with the rest blue? The garage1217 website doesn't give the dimensions of the transluscent vinyl so I don't know if I can cut a circular piece out.
Old Sep 30, 2008 | 07:00 PM
you can manipulate a small strip cut wide enough to place it on the line area.. stretching and then folding as necessary in areas where it doesn't show thru.
Old Sep 30, 2008 | 07:13 PM
SicktC06's Avatar
You replace all the back LEDs white. take your vinyl and without a light table, you can hold it up towards the light (where you can see through the paper/vinyl and the gauge face. take you a tool (I used an exacto) and slowly and lightly mark you an outline of where to cut. then you just cut that out and it's just small trimming from there on out. but just for tips, don't touch the black parts on the gauge face. Finger prints dont come off very easily on there.
Old Sep 30, 2008 | 08:53 PM
^^ ehh.. damp paper towel will take those fingerprints off pretty easily... just the oils in your hands.. that's all.
Old Sep 30, 2008 | 09:29 PM
XSNiper's Avatar
Does anybody know the actual dimensions of the vinyl that garage1217 is selling? Or know of a different source? It would be much much easier to just trace and cut out a circular piece.
Old Sep 30, 2008 | 09:36 PM
different source?
http://www.pacificcoastpaint.com/cat...ransparent.htm
a GREAT deal more material... for MUCH, MUCH cheaper.
you'll be lookin' at the 8300 series.
my guess would be that the place you had looked at gives you a small 8"x10" piece... shoot maybe even bigger... but yea.. $6 or so..
spend $6 at the site i gave you.. before shipping.. you get 24"x (uhh yea..)36"
enough vinyl to do ALOT of cars... and enough extra to not even worry about messing up.
Old Sep 30, 2008 | 10:07 PM
XSNiper's Avatar
I hate to keep shooting out questions but, which blue do you typically use? (assuming you've used this source) They have many different blues, each with there own useless name...I'll go ahead and list out my "things to get" for the gauge mod because I've already come close to making a mistake.
1. Translucent Vinyl from Pacific Coast
2. Reverse LCD from Garage1217
3. 1206 330OHM SMD 1/8 Watt Resistor (x5)
4. 1206 470OHM SMD 1/8 Watt Resister (x1)
5. PLCC-2 SMT Led - White (x14) from Oznium --For gauge faces
6. PLCC-2 SMT Led - Blue (x4) from Oznium -- For LCD and Blinkers
7. Americana Acrylic Paint - White -- For needles
8. Clear Acrylic Nail Polish -- For needles
(and of course all the soldering tools, etc)
Old Oct 1, 2008 | 02:14 AM
the king blue is a nice rich color.
Old Oct 5, 2008 | 10:09 AM
Garage1217's Avatar
Thanks squal you super mod you for steering customers away from a scionlife sponsor, I will remember that
The vinyl I sell and stock is 6x12", plenty to do 2 sets of gauges which is what I can get out of each sheet when I perform swaps in house.
The colors I sell are as close as a match to the actual LED colors as I could find.
Old Oct 6, 2008 | 03:44 PM
trrocks03's Avatar
Question regarding the vinyl:
I put red on there but it isn't nearly as red as the stock red (at the high end of the tach). Does anyone have any idea how to make it more red? It is kinda pinkish
I have white LEDs and the red covers the "MPH" portion. I am thinking I might put another vinyl on top of the one I put there. Any other ideas?
I will do that later today.
Old Oct 6, 2008 | 05:08 PM
Garage1217's Avatar
Double layer it It also is described on my web store under the vinyl to double layer it
Old Oct 10, 2008 | 09:57 PM
XSNiper's Avatar
Ok, so I'm sitting here with my lcd unsoldered. How do you replace the stock filter with the reverse one? Are you supposed to peal something or whats the deal?
Old Oct 11, 2008 | 06:29 AM
Garage1217's Avatar
There is a nice write up on here somplace, you have to remove the stock film by peeling up an edge witha razor blade. Then take it off carefully without breaking the screen. Then remove the old adhesive by useing goo-gone & scraping with a blade. Then you have to apply the film in such a way that the screen looks black. Here are some example pics...
http://www.garage1217.com/GAUGECLUST...elupfilter.JPG
http://www.garage1217.com/GAUGECLUST...removeglue.JPG
http://www.garage1217.com/GAUGECLUST...olarityodo.JPG
http://www.garage1217.com/GAUGECLUST...arizedfilm.MOV
Old Oct 11, 2008 | 09:40 PM
XSNiper's Avatar
I ended up just going for it, thanks for the help though. Now I have to figure out why the AC, Recirc, and Outside temp buttons won't light but everything else does...
Old Oct 13, 2008 | 05:33 PM
SicktC06's Avatar
Check the direction of the LED's. Make sure the notch on the corner of the LED is on the end that the arrow is pointing to.
Old Oct 13, 2008 | 09:54 PM
XSNiper's Avatar
It turned out to be a bad solder. I also switched out the wrong resistor and had to fix that as well. It's all working right now though.
Old Oct 13, 2008 | 11:46 PM
izedaman's Avatar
and the pix is where???? >=)
