Help on Fuel Return Line Setup.. Q?
I have been searching on the net to see how others have installed their fuel return line.. So far I understand running and a hooking it up to the fuel rail and the regulator. The part I'm confused with is the return line inlet at the pump. I know that you drill a hole and place a fitting there just what i've seen is that and more.. not just dropping a line in the tank.. but running it into where the regulator in the pump housing.. IS IT NECESSARY??
Where would you find this?
im really lost on this i was just going to drop a line in tank so lets see you cant do that is there a reason behind it what is ness to make this setup work i have a new fuel reail im going with a walbro intank to 2 walbro inlines ran in parallel feeding the rail with -10 and a 6an return
Im using the aeromotive so this is what i have so far one 255 in tank feedinv two inline 255s with -10to the rail off that 1 foot of -8 to the regulator then -6 back to the tank where do i actually put the return can i just tap it into the filler neck to dump back nto the tank or drill the top of the sender unit dump in there ?
I'm using the Aeromotive bypass regulator. Everything hooks up like stock and route the return line to the top of the fuel pump. I drilled a hole through the metal plate that holds down the fuel pump and a hole in the plastic fuel pump housing. I am in Iraq or I would take pictures. All I did was get a -6AN bulkhead fitting for the top of the fuel pump no hose down in the tank or anything. Works fine with no issues.
Just wondering if I can't get that adaptor just to take out the stock FPR in the pump housing and just fit a hose in there and some how secure it in there.. Would be pretty much what is being done up there in the illustrations above.
I found out that Altered Atmosphere offers a fuel return line setup with the fitting that i have shown in the above illustration.. Complete kit -6 fuel rail, fittings, lines, and regulator, and removes the stock fuel pressure regulator in the tank so you can get the full effect of the aftermarket one.. No images.. They also offer a lot on the tCs but haven't put anything on the website.. they are pretty under the radar.. contact mikem@alteredatmosphere.com nice guy...
YOUR MOM!!!!!! DON'T MAKE ME DROP KICK YOU!!!!!!!
Flyfishfreak
Jun 10, 2016 02:55 AM
