have a little problem guys (SOLVED)
Old Oct 2, 2008 | 04:03 AM
silverstreaktc's Avatar
Default have a little problem guys (SOLVED)
i put my exhaust on last january and i never had a problem until now. the exhaust has always caused backfiring and just a week or 2 ago it sounds like there's a really fast ticking noise and it gets faster as my rpm's go up. i have a feeling that it has something to do with my exhaust valves closing too late and allowing combustion in the exhaust manifold, rather than in the engine. can anyone help me on this? if im right, or what it would be? and how i would be able to fix this?
SO ME AND MY FATHER LOOKED AT IT TODAY (dad was a toyota mechanic for 15 years). turns out that the water pump is the problem.
Old Oct 2, 2008 | 04:12 AM
Kanchi's Avatar
was it used, did you re-use your gaskets? I would also look for black trails around the connections. Sounds like a leak to me...
Old Oct 2, 2008 | 04:13 AM
BZinn1's Avatar
check for leaks........back firing is usually from air getting into the exaust pipe and it ignites the spent gasses......or something like that.......also could caue the ticking sound......does not take much to do it and in colder weather it will get more noticable.
Old Oct 2, 2008 | 04:16 AM
as i said, it didn't start happening until a week or 2 ago. i was just under my car the other day and didn't see any black residue. would it be because theres not enough backpressure?
Old Oct 2, 2008 | 08:18 PM
08superwhite's Avatar
i would definitely say that you have a leak somewhere. check all connections. a small exhaust leak makes a ticking noise that often is confused with the sound of valves
Old Oct 2, 2008 | 10:49 PM
well it sounds like the ticking gets faster when i rev higher. so thats why i thought it was the valves.
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
cid_mcdp
Jan 5, 2015 02:45 PM
DjFrOsT
Dec 13, 2003 04:18 AM
DjFrOsT
Nov 6, 2003 04:54 AM
