Headlights don't work?
Old Oct 4, 2008 | 04:44 PM
sefalik's Avatar
Default Headlights don't work?
This morning as I was driving into work, I realized my headlights don't work. I thought I had noticed it before, but I just thought maybe the TC had dim lights. But today I was on an empty road with no street lights, and I couldn't see.
And yet, the parking lights and high beams work. Actually, from what I can tell, there's just no difference from when I switch from parking lights to normal headlights. Someone at work told me it's probably a fuse. Is he right?
Old Oct 4, 2008 | 05:03 PM
audioandy's Avatar
yea if they both are out more than likely it is just a fuse , but i would check the bulbs just to make sure
Old Oct 4, 2008 | 06:26 PM
sefalik's Avatar
well i just checked the bulbs and the fuses... everything looks fine, but the low beams still don't work.
Old Oct 4, 2008 | 06:38 PM
flintMicaTC's Avatar
i'd just replace the bulbs, they're probably burnt out, and just to be sure replace the fuse to be on the safe side.
Old Oct 4, 2008 | 07:57 PM
XIEmperorIX's Avatar
What exactly did you do to check the bulbs and the fuses? Did you check the voltage where the low beam bulbs harness is at? if your getting voltage to the low beam bulb then its the bulb. No voltage at the fuse then the fuse is bad.
Otherwise you may have a bigger problem
Old Oct 4, 2008 | 07:59 PM
a_german_named_hans's Avatar
are you stock?
Old Oct 4, 2008 | 10:43 PM
sefalik's Avatar
I didn't check voltage, I just pulled out the fuse and pull out the bulb and looked at them.
And yea, they're stock lights. I think. I just got the car a month ago, but it was used 2007.
Old Oct 4, 2008 | 10:51 PM
Thats still not entirely accurate. Both the fuse and the bulb could appear to be fine but something could have happened to cause them to go bad.
Without checking voltage all you can really do is swap bulbs/fuses and see if that works. If its just the low beams that aren't working its a good chance thats what it is. But otherwise, without a meter to test with it might be difficult to trace the problem.
Old Oct 4, 2008 | 11:45 PM
sefalik's Avatar
Well I'll try some new bulbs I guess, and if that still doesn't work I'll just have to call up a Toyota dealer. It's still under warranty.
Thanks for all the replies.
Old Oct 5, 2008 | 06:24 PM
sefalik's Avatar
i just replaced the low beams, and everything's working fine now.
Old Oct 5, 2008 | 07:16 PM
Coolwaterz's Avatar
lol....replacing solves everything.
Old Oct 5, 2008 | 07:25 PM
XionLion's Avatar
damn,,, i was just about to say throw the car away.......
scsteven
Jan 25, 2015 01:06 AM
TheTripleC
Jan 4, 2015 06:46 PM
Kiwibox
Dec 15, 2014 09:46 PM
jpn6438
Dec 12, 2014 08:09 PM
LeChuck
Dec 9, 2014 02:26 AM
