View Full Version : YELLOW HEADLIGHTS!!
hansta
10-12-2008, 07:24 AM
i just installd nokyuo? or something like that...
yellow bulbs from them and here's a lil tip in you guys ever have to pull out the bulbs...
UNPLUG YOUR BULB BEFORE YOU TAKE IT OUT OF THE HOUSING!!!!
it's so compact inthere and the clip that's holding onto the bulb is in such an awkward angle (and yellow greesy stuff i don't know what it is..)
tc had the plastic cover for the bubl and i was suprised to see just like rubber cover protecting the bulbs...
but anyways, i have bright yellow lights and i think it's sweeeeeet.
i haven't driven at night yet tho, that things like waving at the cops like"HERE GIMMMMEE A TICKET@@!" haha
here's a dumb Q...how do i post pictures...?? i should check but that search tool never works..
draxcaliber
10-12-2008, 07:26 AM
doesn't it use the same bulb for the high and low beam? it is a dual filament bulb, which means you can't have two different colors for the high and low beam.
hansta
10-12-2008, 07:27 AM
like you switch to high and low beam turns off??
draxcaliber
10-12-2008, 06:49 PM
okay, lo9ok at your tc, you see two separate housings in each headlight, one for the low beam, one for the high beam, the high and low beam are separate bulbs.
but on the xd, it uses the same bulb for both the high and low beam, but that one bulb has two filaments in it, one is brighter than the other. so you can't have different color high and low beams on the car without having two separate bulbs for each color. so you have to pick one color.
