Any HP or Torque plus or minus to going dual exhaust?
Popular wisdom seems to be that power increases less than 1HP by "upgrading" from the xB2 oem exhaust. Is this also "true" for ft-lbs of Torque, and does it make any difference whether it's single or dual exhaust (eg. Borla and Tsudo)? Do SR or CAI or light weight crank pulley make any difference?
I'm hoping for something more substantial than the typical lay sidewalk opinion -- all solid input appreciated -- TIA! (Dyno info would be great !)
PS. I realize the crank pulley can only have an effect during acceleration (rpm spin up,) as opposed to during steady rpm. Therefore, I wouldn't expect it to have a dyno impact, only a throttle response impact.
I had a tC and the main restriction on that exhaust was the axleback because of the chambered design as well as the flap that opened under high pressure. For the xB2 it lies mainly in the MOAB in the mid pipe which is a cat/resonator combo. The axleback portion too is slightly restrictive but not so much as the NUKE.
yeah, but removing the NUKE or SCUBA tank makes the exhaust very loud according to posts. Thinking of a small high flow cat in line with small resonator to get rid of Mr. SCUBA. Maybe go to Weapon R "S" pipe at same time.
Well after seeing what the tc guys have to do to get rid of rasp you will either need a resonator as large as you can fit + a cat or two resonatoors. Another option would be a glasspack + a cat. As far as exhaust goes I remember seeing a dyo from weapon-r that had dyno results with exhaust. I think it made a noticable differece but I do not remember the exact numbers off hand. try searchig "dyno" under this subdivision of the forum as there hasn't been much talk of people dyoing thier rides. You should find it easy.
Borla exhaust single outlet
I ordered the borla single outlet, but I have not gotten it yet . The borla web site says its 9 dbs louder than stock. I hope that it's not too loud. I want more than the TRD sound but not that fartcan **** sound when I step on the gas.
that's going to be next mod. header with some heat protection for my short ram CAI. Weapon S pipe. then the challenge. suba out and custom cat+resonator in. My tusdo dual will bolt to that. Trumpets still in tusdo which should help. If it's loud and raspy will be bummed.
Originally Posted by AAG
All the xb2s i've heard without the scuba tank sound very raspy & don't sound good at all. I'm leaving mine on unless I go boost (which wouldn't be any time soon).
EV_AIC-xB
11
10-15-2003 11:57 PM
