installing rotors.neeed help!plz
Old Oct 23, 2008 | 04:55 AM
k1ng1's Avatar
Default installing rotors.neeed help!plz
i just ordered cross drilled and slotted rotors..can someone please help me on how to install them on my tc>? i need pics thanx
Old Oct 23, 2008 | 04:58 AM
cavalierkid888's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=86011
Should help you out, once you get the caliper off should be pretty obvious what to do. Just pop off the old rotor and put in the new one.
Old Oct 23, 2008 | 05:00 AM
k1ng1's Avatar
so i dont have to remove an axle nut ?
Old Oct 23, 2008 | 05:03 AM
Don't believe so, here's a diagram of the front brakes for you. Might help out a little, the rears should be very similar.
Old Oct 23, 2008 | 05:07 AM
k1ng1's Avatar
today i took my wheel off..then i took my caliper off...it looked like i needed to take the axle nut off...so i went everywhere tried almost every socket..nothing fits...i cant take the rotor off! its liik wtf..
Old Oct 23, 2008 | 05:18 AM
Did you try tapping it with a hammer? Maybe its just stuck on there...
Old Oct 23, 2008 | 05:20 AM
xIxAMxHOLLYWOODx's Avatar
yea, your rotors are gonna be stuck on there pretty good. If you are putting new ones on you might just wanna whack the cr@p out of it with a mallet or hammer.
Old Oct 23, 2008 | 05:22 AM
k1ng1's Avatar
yea i did with a rubber hammer
Old Oct 23, 2008 | 05:23 AM
its gonna have to be hard. its ceased on there. Nothing holds it on.
hit it harder...
Old Oct 23, 2008 | 05:24 AM
k1ng1's Avatar
let me ask this.....after i take my wheel off...and after i take my caliper off...what is supporting the rotor after i do that??
Old Oct 23, 2008 | 05:25 AM
jurassic1's Avatar
No, you don't need to take the axle nut off. lol! Try a few smacks w/ a hammer to loosen it. Another way is you could screw in a right-fitting bolt into the hole near the studs close to the center. The holes are there so when you screw in a bolt in there, the bolt will push the rotor out.
Old Oct 23, 2008 | 05:26 AM
supporting? your lug nut studs, like iamhollywood said it's just seized on there
k1ng1's Avatar
hahah wtf? man..
nothing, your wheel sandwiches the rotor in between it and the axel
Old Oct 23, 2008 | 05:29 AM
jurassic1's Avatar
hit it harder...
Yup, like I said. Don't be shy, dude! Whack it like you're mad at your gf or ex, whatever! Hyhaaa!!!
Or, just screw in a bolt to push it out.
Old Oct 23, 2008 | 05:30 AM
k1ng1's Avatar
alrite peeps...thanx for everything im back on it tomorro thanx...
Old Oct 23, 2008 | 05:31 AM
from heating and cooling, water and corrosion, the rotors get stuck to the axle pretty good. I tried to take mine off the other day to locate a squeak Ive been having and I gave up. And I have over 50k on those rotors. Im gonna have a hell of a time replacing those bad boys I know it. I just didnt want to damage them cause its not time to change them yet...
Old Oct 23, 2008 | 05:37 AM
jurassic1's Avatar
This should be a nice link to save for future reference. Hope it helps:
https://www.scionlife.com/forums/vie...ght=rotor+swap
Old Oct 23, 2008 | 06:22 AM
Hyghgynx's Avatar
The rear brakes are cake. For the fronts, do what the people have stated; smack it!!
Old Oct 30, 2008 | 10:27 PM
Andrew1782's Avatar
Or....you can use one of the bolts from the front radiator plate and thread it into the small screw holes on the hub and continue threading in until the rotor pops off.......
Works like a charm!
