View Full Version : 205/40/18 Tires for Enkei CDR9s
EastTNScionxB
12-23-2004, 04:53 AM
I'll confess, I am a newbie! :? So I need some help! Will you help me find tires for the Enkei CDR9s I want to buy? I am looking for a 205/40/18 tire. I prefer the Pirelli P Zero Nero M+S.......I have those on my IS300 and love them. Anyway, any help you can offer would be greatly appreciated. :D
hotbox05
12-23-2004, 04:57 AM
those r awfully skinny tires. that and the wrong size i believe. or maybe theyre right.
EastTNScionxB
12-23-2004, 04:59 AM
The Enkei CDR9s I am getting are 18s.....according to a couple of the more experienced guys on the site......205/40s won't rub cornering or on bumps.
hotbox05
12-23-2004, 05:06 AM
yeah that's true. just skinny tires is all. what kinda drop u gonna get?
LowProMofo
12-23-2004, 05:10 AM
I wouldn't run that small of tire. I run Goldlines on mine with those same rims and 215/35/18 Nitto's on mine. I've never rubbed at all. You'd run the risk of messing up your rims with potholes and curbs with that skinny of a tire.
hotbox05
12-23-2004, 05:13 AM
umm ... yes and no. more risk of messin up the front or back face of the rim .about the same risk of pothole damage. only diff is traction , and ride. better traction wit 215/35 but better ride with 205/40 well probably better.
EastTNScionxB
12-23-2004, 05:24 AM
Am I looking at any rub with a 215/40? I am going with the Goldline drop. I want flush and a little more rubber than a 35 gives.
hotbox05
12-23-2004, 05:29 AM
a 215/40 yes a 215/35 more than likely no.
TOAST3R
12-23-2004, 05:33 AM
i had 215/40/ on 18x7.5 rims on mine with the trd springs and had no rubbing
EastTNScionxB
Why does such a small difference cause a rub? I mean, we are talking a very small amount of difference. I am sorry for the ignorance, I just want to understand.
EastTNScionxB
12-23-2004, 05:36 AM
The Enkei CDR9s are 18x7 That shouldn't rub if the 18x7.5s TOASt3R had didn't.
hotbox05
12-23-2004, 05:39 AM
he also had a 1 inch drop. it also has to do with the offset of the wheels. r u planning a drop lower than 2 inch? and do you care if yer speedo is off? cuz a 215/40/18 will mess up the speedo.
EastTNScionxB
12-23-2004, 05:43 AM
I don't want any speedo variance. I am dropping the 2" with Goldlines. Let me ask it this way.....will 215/35/18s give me enough protect on smaller potholes and keep me from rubbing?
TOAST3R
12-23-2004, 05:44 AM
it doesnt throw it off much at all, at 60mph you will be going 2.1 mph faster
the tires were what the dealer put on when i got 18" rims from them
EastTNScionxB
12-23-2004, 05:46 AM
Doesn't that mess with the odometer a little bit too? Seems like 18s are too much of a hassle. Maybe I should go back to looking for 17s!
TOAST3R
12-23-2004, 05:50 AM
ya but to your advantage, you car has 3.5% less miles on it than it should show
hotbox05
12-23-2004, 05:51 AM
thats what i'm doin but big rims are dope lookin for most people. and if only small potholes yes 18's with 215/35 should be fine anybig potholes could be bad tho .
EastTNScionxB
What kind of speed variance do you have at 70mph?
TOAST3R
12-23-2004, 05:54 AM
2.45mph faster than speedometer
just add 3.5% to whatever speeed you are going for correct speed. 100mph 3.5mph faster than speedometer
EastTNScionxB
12-23-2004, 05:56 AM
Ok.....so let's get this straight.....I will be protected (with attentive driving) getting 215/35/18s and I will have no rubbing and no speed variance. Is that correct?
hotbox05
12-23-2004, 06:02 AM
yes. just becareful with any rim larger than 16. potholes can be hell but i've never had probs with the 17's on my supra , the 16's on my bimmer or the super thin 17's on my buddies integ then miata. it's all about attentive driving.
EastTNScionxB
12-23-2004, 06:06 AM
Yeah......I have 17s on my IS300. I have hot some mega potholes when visiting other cities and fortunately nothing has happened. I appreciate all the help guys. I think I will go with the 215/35/18s then, and it's my lucky day.......Pirelli makes the P Nero Zero M+S in that size!
hotbox05
12-23-2004, 06:10 AM
nice a m+s 17 lol. nothin like a low pro mudder lol .
EastTNScionxB
12-23-2004, 06:12 AM
M+S 18! lol Even better! I only want them so I don't have to use different tires in the winter. We don't get enough snow here to make a difference.
Orataro
12-23-2004, 06:20 AM
I'm running 215/35/18/8.5" and have no problems rubbing. In fact, I'd love to drop my xB even more with my Goldlines.
EastTNScionxB
12-23-2004, 06:22 AM
The how on earth would a 215/40/18x7 rub at all? I am getting even more confused!
hotbox05
12-23-2004, 06:26 AM
off set. that and they are decently wide.i mean stockers are 185/60/15's with what a 40mm offset. so u run a 32mm offset with 215 and a 2 inch drop with standard camber and rub city.
EastTNScionxB
12-23-2004, 03:14 PM
bump
johnrz2007
12-23-2004, 08:10 PM
you mean bigger wheels means that your odo runs slower? correct me if I'm wrong.
EastTNScionxB
12-23-2004, 08:14 PM
Yes, I have been educated that it will run slower, but faster speeds on the speedo
johnrz2007
12-23-2004, 08:25 PM
thanks
EastTNScionxB
12-24-2004, 03:16 AM
bump
Craig_X1
12-24-2004, 03:23 AM
I have 225/40/18 and get a slight bit of rub just before full lock. I think with anything smaller it would be ok. I have Enki RS6 18x7, offset of 38.
SenseiRick
12-26-2004, 03:47 PM
I just finished ordering 18" Axis TC Evo for my Polar White XB
the rims are dark charcoal and I am painting the
white lip to match the car.......... I also ordered H&R 1.5" Springs
I plan on using 215/40/18 - to give it better protection against potholes...
I think the drop and the tire size should flush out perfectly..........
I also have 18" Motegi's w/ 225/40/18 & 255/35/18 + Eibach pro-Kit
on my s2000 and it works fine...
http://www.s2ki.com/forums/index.php?act=module&module=gallery&cmd=viewimage&img=188886
http://www.s2ki.com/forums/index.php?act=module&module=gallery&cmd=viewimage&img=188887
the plain toaster:
http://www.s2ki.com/forums/index.php?act=module&module=gallery&cmd=viewimage&img=194830
the concept photo:
http://www.s2ki.com/forums/index.php?act=module&module=gallery&cmd=viewimage&img=194831
hotbox05
12-26-2004, 07:31 PM
damn people are runnin 225 tire setups? man that is just asking for rub. not a flame but hasn't anyone on here heard of rolling resistance. not only will that heavy rim tire combo slow you down but those super wide tires also slow you down. i mean they may yield a lil extra trac and cornering but man.
SenseiRick
12-28-2004, 02:11 PM
Hey man I am running 225's on my Honda - that the perfect setup!
My friend has a TT Supra running 325 in the rear - how bout them apples!
225 front - 255 back on a sports car is normal??????????
