smoke coming out of my hood
Old Oct 30, 2008 | 12:39 AM
bigBOAT's Avatar
Default smoke coming out of my hood
so i have a 2005 scion tc with a zpi stage 0 kit. i noticed to that my breater on the top of the engine has smoke coming out of it when i drive it a little bit.i havent been it boost for a while due to much slipping clutch. please help.
Old Oct 30, 2008 | 12:40 AM
tCtCtC's Avatar
try a oil catch can
Old Oct 30, 2008 | 12:42 AM
bigBOAT's Avatar
could it be burning oil? from that. i have noticed a little drop in oil level
Old Oct 30, 2008 | 12:43 AM
tCtCtC's Avatar
is there any smoke coming out of your exhaust?
Old Oct 30, 2008 | 12:44 AM
bigBOAT's Avatar
yeah. a little white and black
Old Oct 30, 2008 | 12:46 AM
tCtCtC's Avatar
are you sure its white? and not like white/blue?
are you tuned?
Old Oct 30, 2008 | 12:52 AM
kikcaffine's Avatar
first to say compression test! YES! I was that guy.
Old Oct 30, 2008 | 12:55 AM
java09's Avatar
^^damn it! you win this time.
Old Oct 30, 2008 | 12:57 AM
es_05's Avatar
dude just save up money!!!! most likely ur piston rings are craked!!! this exact thing happened 2 me!!!
Old Oct 30, 2008 | 01:41 AM
purplenitroustc's Avatar
piston rings/piston landing
same thing
Old Oct 30, 2008 | 01:58 AM
StreetStarsTc's Avatar
i had a similar problem when i was open dump but it went away when i put my exhaust back on obviously lol but the thing is, could there still be an issue of piston rings cracking?
I've yet to do a compression test.
Old Oct 30, 2008 | 02:24 AM
thendawg's Avatar
this sounds crazy but yea open dump caused my turbo to leak oil like crazy lol - what happens is when the pressure in the chra oil flow is higher than the pressure on the turbine side it allows oil to pass by the piston ring seal - so putting a lil more back pressure on the exhaust and walla its gone lol
Old Oct 30, 2008 | 02:26 AM
thendawg's Avatar
one edit - the turbine side oil piston seal was already pretty shot - it shudnt just do this easily Itll just make an existing issue very apparent
hmmm makes somewhat sense, that is what i had assume that the loss in back pressure had caused it but at first i started buggin because i was like OMGZ everything just went boom but nope
yay lol
Old Oct 30, 2008 | 02:30 AM
thendawg's Avatar
O yea it was a tnetics turbo too lol you might have the same issue - our high egt seems to create an issue for this turbo do to the oil flow design but apparently the water cooled chra will correct this - hopefully so because i have a tnetics turbo 50 trim thats sitting on my desk with water chra
Old Oct 30, 2008 | 02:36 AM
haha
well i do have the tnetics turbo with the coolant line, i do have a small leak, that could cause it as well....damn coolant lines
Old Oct 30, 2008 | 02:40 AM
thendawg's Avatar
coolant shouldnt be able to leak through turbo to the exhaust its a completely seperate cast passage in the chra if its leaking there thatd be really bad it means ud hav a hole in the chra :/
Old Oct 30, 2008 | 02:43 AM
well i meant in the coolant hose that connects to the turbo, there might have been a few drops that got onto the dp or something hot that caused the smoke?
Old Oct 30, 2008 | 04:57 AM
bigBOAT's Avatar
so do a compression check. then go from there. but from what i reading here sounds like a piston??? f uck!
Old Oct 30, 2008 | 05:12 AM
bigBOAT's Avatar
and i would say the smoke is a little white and blue but not very ofter only when i get on it
