View Full Version : Questions about ECU reset...
cartier001
12-24-2004, 06:50 AM
Should I reset the ECU while the engine is hot or cold?
What should I do after reset the ECU? Let it idle for minutes or hit the road?
Any help would be appreciated.
sexyscionlover
12-24-2004, 06:54 AM
i dont think the temperature would matter much, but just incase i might start it in a garage. everytime you reset it im told you should let it idle for a couple minutes, then get going. i guess it has to readjust. that may be old wives tales but i do it any how
Craig_X1
12-24-2004, 05:10 PM
Can I ask why you're resetting it?
cartier001
12-24-2004, 05:19 PM
I had reset it couple times and I drive the car immediately afterward. I'd found the car is running rich gas mixture. and I smell gasoline from the back of the car at cold start up.
dgHotLava
12-24-2004, 05:24 PM
after you reset the ECU the emissions need to re calibrate...
the exhast needs to be hot so that the sensors by the cat. read properly...
but as it a learning ecu it should adjust either way....
cartier001
12-24-2004, 06:05 PM
What a Pro. thanks for your info.
hotbox05
12-24-2004, 08:42 PM
yeah every time you reset it just learns quicker than if u change something and do not reset. it( the ecu) has a learning curve and will adjust to your driving style for best perf and economy. (to an extent . it's factory you can't ask for too much)
