My black 09' lowered on TRD's
I have read that I should get a front wheel alignment after the springs, is this necessary? As far as I can tell it doesn't seem out of alignment to me, but if it's necessary I will.
I guess I could just take to an auto shop and have them check to see if it needs it.
alignment isn't something you can eyeball. wait around 2-3 weeks, the average time it takes for springs to settle, and then get an alignment. any suspension work should be followed up by a alignment.
What about headlight adjustment, How much is the standard for lowering them down?
After I dropped mine on Tanabe springs, it drove straight, and didn't pull either, but my toe-in was between 3 and 4 times what it should have been. Car drove fine, but tires would have worn very quickly.
It's your car, and they're your tires, but I saw a $60 alignment as cheap insurance against $400 worth of tires.
Originally Posted by curtisc
How is the ride compared to stock?
p.s. get it after it settles, or else you're basically throwing money out the window. as it settles, your alignment go more and more out of spec
[quote="Aroddalobster"]
alignment doesn't only fix pulling. there's also camber, caster, toe, all that ish, but i'm sure you'll have a bit more camber than necessary, meaning your wheels are going to look a little like / \ from the front/rear. small adjustments, but it'll help your tires last a bit longer, and handling.
Do I need front & back whell alignment or just front? I thought I read somewhere that I only needed front, the back alignment was bs a machanic was feeding someone.
Originally Posted by jingjing
looks good. im waiting on the next shipment of tanabe nf210 springs. its kinda of a toss up between the trd's and nf210's. ive heard alot of good reviews of the nf210's.
TRD = 1"F/1.5"R drop, spring rate about 10% stiffer than stock.
NF210 = 1"F/1.7"R drop, spring rate about 5% stiffer than stock.
The Tanabe springs ride a little more comfortably (really nice if you're on 18/19/20 inch wheels) and let the rear sit closer to level; however, if you're pushing the edge of wheel/tire fitment with +35 offset wheels and 235 tires, then the softer NF's will rub over bumps & dips, whereas the TRD's usually won't.
Here is a set of instructions if you are inclined to give this a shot yourself.
http://www.trdsparks.com/install/xBH...Adjustment.pdf
