i need some exhaust input
Old Nov 4, 2008 | 03:24 AM
joeya28's Avatar
Default i need some exhaust input
ok so my set up is alpha works header, megan s-pipe, megan mid with a resonator, HKS hi pwoer axel back.
so its a little annoying on the high way and i might have a leak after the header, and it shakes because i didn't use the brackets that hold the header at the bottom. so my options are
1. keep what i have and try to fix the leak and put the bracket on
2. remove the header and get a OEM style exhaust
3. remove the header and keep the HKS
4. ideas?
Old Nov 4, 2008 | 03:42 PM
joeya28's Avatar
bumd
Old Nov 4, 2008 | 05:34 PM
Mouse's Avatar
the easiest way to fix the problem is to install the bottom brackets. I'm a mechanic...have been for years... it is really not wise to run your exhaust like you are. they are easy to install. I would use a little mid-level (red in color) loctite on the threads prior to installing the bolts. You will still be able to get them back off if you need to, and that level/grade loctite is designed for that temperature range of exhaust systems. I'm not sure on the Alpha Works header, but on my Megan Racing header I had to slightly notch out 1/4 inch one of the mounting brackets to fit correctly. That should fix your problem. if you have any questions... just shoot me a pm and I'll help you out.
Old Nov 4, 2008 | 05:38 PM
toeveryhour's Avatar
1 or 3
Old Nov 4, 2008 | 05:49 PM
AGTC85's Avatar
fur_pig
Mar 20, 2020 04:28 PM
nazblue5807
Apr 11, 2015 12:20 AM
toyotaisme
Jan 10, 2015 10:24 PM
RichBinAZ
Dec 21, 2014 12:05 PM
kdanie
11
Jan 23, 2004 04:47 AM
