Regional - Mid Atlantic DC, DE, MD, VA, WV
Will Someone Help Me?
Old Nov 6, 2008 | 09:17 PM
luvmytc12's Avatar
Default Will Someone Help Me?
http://www.scionevolution.org/forum/...ic.php?t=26057
Old Nov 7, 2008 | 04:32 AM
BYeRhONe's Avatar
http://www.flowlighting.com/Single_C...structions.pdf
looks easy enough.
Old Nov 7, 2008 | 04:53 PM
black_xb's Avatar
The hardest part wil be figuring out where to mount the lights.. How many holes you want to drill? the eltrical part is just as easy.... Get a mini fuse pigback not sure what its called... you will pull out a fuse plug this into the fuse panel put the fuse you pulled out in it and a fuse to protect the circuit your gonna power and thats your power source.. Throw a toggle switch on it and connect the positive wires and your done.. If you do this you will want to find a fuse that is switched on w/ the ignition.
