Buddy wants his xA tuned up
It's an '05 with about 120k on it and the 5 speed.
He currently has Amsoil synthetic in there right now so we're not "switching" to synthetic, really.
I'm thinking:
Oil/filter
plugs/wires
gear oil
fuel filter
For the oil and filter, I'm probably going with Amsoil, it's dealer cost to me and the extended use is perfect for a guy with his busy work schedule.
OEM for plugs/wires? What's the expected cost?
Gear oil, I'm thinking about Amsoil again. I use Amsoil in my car right now and it's been fine.
What about the fuel filter?
I'm thinking:
Oil/filter
plugs/wires
gear oil
fuel filter
Plugs should cost ya abut $12 from the dealer for the set...coil on plug design so no wires. I have Royal Purple Synthetic in the gearbox, works great. I have no clue about the fuel filter. All I know is that its inside the gas tank.
Here is a full list considering the 100K on the clock..
Grab a set of Iridium plugs, toss a new PCV on there, squirt down the MAF sensor with the cleaner, fuel filter only if needed (if he has a fuel problem),Air filter, mount up a new set of wiper blades and fill the washer fluid, coolant flush and fill, you said oil/filter and tranny which are good but remember the extended Amsoil will still need a oil filter change and top off every 4-5000K as the filter won't go the distance. Take a look at the front sway bar bushings and brakes, check the power steering fluid for fun..
Yeah that will keep you guys busy for a bit!
vi3tb0i09
Sep 23, 2015 08:32 PM
