View Full Version : Throttle Body
toyota_scion_tc 12-25-2004, 07:40 PM What size is the oem throttle body? Has anyone found any aftermarket ones that are available ex. bbk,holley,edelbrock,and str? I have been searching the only one I have found so far was an oversized 60mm tb. I want either a 62mm or 65mm. I had a civic with a 1.5Lnonvtec motor with i/e/h and I put a 62mm it screamed afterwords. Any one have any ideas what a good size to go would be for n/a setup? I leaning towards either the 62 or 65mm(more so to 65mm).
smurf3642 12-25-2004, 11:21 PM I would think the 60 would do great on this 2.4...
but not very experienced with TB's...
Just give the tC more time to get more parts made for it...
toyota_scion_tc 12-29-2004, 08:32 PM I measured our throttle bodys they are 55mm. So a 62mm would do great when its available.
its_ikon 01-03-2005, 05:31 PM why not take it to a performance shop and have it bored out with a new valve added? should be in the 250-350 range in price
toyota_scion_tc 01-03-2005, 08:51 PM why not take it to a performance shop and have it bored out with a new valve added? should be in the 250-350 range in price b/c when I change the tb I will also by-pass the heater. When you buy aftermarket ones most of them will not have the place for the heater it will be solid. I just don't like bored tb. I prefer built ones not bored ones.
Gmoney 01-03-2005, 08:59 PM i put a bored TB on my escort zx2 and it cleaned up the power band very nicely, plus added some awesome throttle response!
smurf3642 01-03-2005, 10:30 PM does increasing TB size reduce gas mileage??
Do you have to redo anything on the ECU??
or, does it just allow for more airflow??
toyota_scion_tc 01-04-2005, 12:29 AM does increasing TB size reduce gas mileage??
Only if you stay in the pedal. My honda civic I had got 37-38 best mpg stock. I put cai/ 4-2-1 headers/2.5 race exhaust/ ex transmission (lower gearing) 62mm tb (compared to 55mm stock). I got 44 a few times I 43 most of the time. And thats with lower gearing. It just allows the engine to breathe easier. Just don't go too big. I belive 62 mm on the tc would do great. Noting needs to be done with the ecu. If you have i/h/e/tb. then you might want to chip it b/c It should sqeeze some more power out when dyno tuned properly.
hahaitzskippy 01-04-2005, 01:40 AM bore? TB?
built TB?
dunno what does mean
toyota_scion_tc 01-04-2005, 01:48 AM bore? TB?
built TB?
Built means the company builds it from scratch all new parts used. Bore means they take your used one and bore it. They build a new butterfly for it.
dgHotLava 01-04-2005, 01:52 AM moved..............
k20a3epsi 01-10-2005, 06:40 AM the tc only has a 55mm throttle body?!
my 2.0 ivtec comes with a 62.5 mm throttle body stock
This means that with more air flow....ALOT of power can be had (esp since it's a 2.4) for just a bolt on. 65mm would definitely be ideal for a 2.4 n/a motor.
jmiller20874 01-10-2005, 03:34 PM Sciontcperformance.com has a 60mm throttle body for just $295 with core exchange.
Scion tC Performance - Throttle Body (http://suzukird1.netfirms.com/scion-tc-performance/nfoscomm/catalog/product_info.php?products_id=8&osCsid=d3d3a2750b128bb0a5a25092992fd2c0)
CMoney 01-10-2005, 05:26 PM Sciontcperformance.com has a 60mm throttle body for just $295 with core exchange.
Any dyno numbers anywhere for that?
apexjr 01-10-2005, 06:12 PM Dyno, what is that? That is the problem with a lot of people, esp at the begining of a new car. Everyone wants to make a quick buck and turns out the products with no claims to the gains! I wish they would start backing up there products with a tested dyno sheet and comments from people who have bought the product and also had it dyno'd. How hard can it be to slap on a part and take a couple second run on the dyno? Not very.
It's not that they haven't provided us a dyno, it is just that they didn't show us seperate gains per item they added to the car. Combined is nice for a goal approach, but are we going to drop another $260 with core exchange on a TB if it only up'd the HP/TQ a 3points? Not likely.
jmiller20874 01-10-2005, 07:24 PM I'm not affiliated with Scion tC Performance. I am just a fellow Scion Lifer who was giving the man some info based on a question he asked.
After reviewing the dyno sheets they provided I thought that the gains were reletively modest (23 WHP/ 20 TQ) considering they replaced the intake, TB and full exhaust. I was expecting to see somewhat more of a gain but that's just me. I agree with apexjr that they need to show dynos of before and after the TB.
But based on what they give
http://suzukird.com/scion-tc-performance/nfoscomm/catalog/Dyno_charts/4_air_int_header_exhaust.jpg
Without TB
http://suzukird.com/scion-tc-performance/nfoscomm/catalog/Dyno_charts/5_air_int_header_exhaust_tb.jpg
With TB
Difference = 1.42 HP/0.96 TQ = not worth $295!!!
toyota_scion_tc 01-10-2005, 08:38 PM tb is too small. Someone needs to actually make a 65mm for it. I had the 62mm on a 1.5 non vtec in the civic. My friend has a type r and has 67mm on his. The type r (integra) has a 1.8 engine in it. Stock tb size for it is 62.5. So being a 2.4L which is pretty big for a 4-cylinder I belive just changing the tb would help it breath a lot better. When a company actually makes a 65mm I will buy it and dyno. I am pretty certain there would be a significant gain with just a tb. Does anyone know what size the celica gts tb is? whould it bolt to tc? does it have electronic throttle?
Chaos_Being 01-10-2005, 09:24 PM may be a dumb question, but what is involved in installing a new tb? Is it a bolt-on with similar difficulty as intakes or headers to install?
toyota_scion_tc 01-10-2005, 11:28 PM its about the same. I belive our tb's only have four bolts, electrical connector, and two small coolant lines.
CMoney 01-10-2005, 11:47 PM tb is too small. Someone needs to actually make a 65mm for it. I had the 62mm on a 1.5 non vtec in the civic. My friend has a type r and has 67mm on his. The type r (integra) has a 1.8 engine in it. Stock tb size for it is 62.5. So being a 2.4L which is pretty big for a 4-cylinder I belive just changing the tb would help it breath a lot better. When a company actually makes a 65mm I will buy it and dyno. I am pretty certain there would be a significant gain with just a tb. Does anyone know what size the celica gts tb is? whould it bolt to tc? does it have electronic throttle?
I'd be interested to see the dyno numbers. Problem is finding someone who makes one... could you have a machine shop custom fab one?
toyota_scion_tc 01-10-2005, 11:54 PM I don't know if a machine shop can make one or not. I am sure if the price is right they can. I'll just wait. I am going overseas soon and I will be there for a few months. So hopefully there will be a lot of aftermarket parts available when I get back. When I get back I want to get a cold air intake, tb, header, full exhaust or an axle back and definate trd suspension. I emailled a company that has a bored tb now to ask them if they are planning on making an actual big bore tb. They said it was in the works.
sciontcperformance_com 01-12-2005, 05:53 AM We at www.sciontcperformance.com, want to share with you some of our experience with the TB for the tC.
Reviewing the messages posted before, we agree with most of them in regards to the boring of a "regular" throttle body, that is, those ones that are manual and use valves.
The Scion tC has a drive-by-wire system that uses electromagnetic signals for the Throttle position and a motorized system as actuator. This particular "modern" TB is very delicate to work with and any mistakes will give you a long time trying to put everything back in the right place in order to eliminate the DTCs about TPS and WOT.
The tC has a plastic intake manifold that will not allow more than 60 mm, so it is the maximum you can go.
Going from 55 to 60 is an actual improvement that combined with other upgrades will make a faster car. For all of you that plan on supercharging, turbo charging or going Nitrous, it will make a huge difference.
As far as uninstalling/installing goes, it’s as easy as: 1 electrical connector, 4 bolts and 4 hoses.
Here is a picture of the scion tC Throttle Body:
http://suzukird1.netfirms.com/scion-tc-performance/nfoscomm/catalog/images/scion-tc-pics/scion_tc_tb.jpg
toyota_scion_tc 01-12-2005, 09:14 AM That makes sense why there wasn't a huge gain then. When someone come out with a diffrent intake manifold. There will be more gain to have.
hahaitzskippy 03-04-2006, 07:01 PM hehe...
i believe
www.goldeneagle.com
is making all the NA parts for our car.
they already have sleeves, they are working on cams and TB as we speak
TCpete 03-05-2006, 04:32 AM im specifically waiting for cams.. thats really going to be the best bang for any of us N/A guys.. hopefully a cam design will come out soon .... *praying to the gods*
l3rl4n 03-05-2006, 05:22 AM hrrmmmimay save the money for the enkei evo 5's and invest in cam/TB/I-manifold That would be soooooome sweet! Already have the I/H/E done :)
