TRD SC Injector Color? Wrong part numbers?
Old Nov 10, 2008 | 11:14 AM
Jacque766's Avatar
Default TRD SC Injector Color? Wrong part numbers?
I'm confused and I have searched for awhile!
Part numbers I see show that the S/C TRD 400cc INJ are PTR01-21050-20
and that the stock ones are 370cc with part number 23250-YW201 printed on the side and olive green in color.
Is this correct? Why do I see people claiming they are selling TRD injectors but list the 23250-YW201 part number on the injector. Are they wrong?
So what is it? Are the 400cc INJ turquoise and the stock 370cc olive green?
Those of you with the true S/C TRD injectors what part number is stamped on the side! What color were they?
I bought the Denso olive green colored ones with 23250-YW201 stamped on the side but everything I see and read says they are the stock size.
Thanks, Jason
Old Nov 11, 2008 | 06:33 PM
hunterUnknown's Avatar
if you have that part number already, then you have trd injectors. im certain of it. hopefully someone else can chime in on this.
Old Nov 11, 2008 | 06:36 PM
jonathan110987's Avatar
arent the stock ones a lighter green than the SC ones... mine on my SC are a darkish olive green...
Old Nov 12, 2008 | 02:54 AM
im 100% sure you already have trd 410cc injectors. i just checked my second set of injectors in the "new" kit i have and it has the same part number.
i think it'd be good if someone else did check their injectors on this too as further proof.
oh oh call up a dealership's parts department and give them that part number!
Old Nov 12, 2008 | 04:53 AM
sonofabeoitch's Avatar
i have wondered about this also, the original ones i have were light green. and the ones that was in the trd box was closer to an olive green. my kit was a used kit.
Old Nov 12, 2008 | 07:22 PM
rsdubya's Avatar
I checked with my parts dept. and if you're looking for your 2005 (my assumption), this is the part number I found for the injectors.
Service Parts, TRD 2.4AZ S/C, Fuel Injectors, High-Flow
PN: PTR41-21163
Set of 4 400 cc fuel injectors
tC 6221 2-DR 4-cyl Manual 2005 - 2006
tC 6220 2-DR 4-cyl Automatic 2005 - 2006
Hope that helps. :D
I'd check with your local Toyota parts dept. also.
Old Nov 12, 2008 | 08:16 PM
Jacque766's Avatar
PN: PTR41-21163
Hope that helps. :D
THanks guys. Yeah I have the dark olive green ones too. The confusing part is that the part numbers mentioned are not whats written on the Injector itself. On the injectors the number is "23520-YW201" but now that Im thinking about it.....I think that PTR41-21163 number is on the other side.....have to double check when I get home. It just sounds familiar.....
I dont know what is actually written on the light green ones.
J~
BrokenTC2
Jan 27, 2015 03:32 AM
randomsuper
Dec 5, 2014 11:14 PM
umnitza
Dec 1, 2014 06:26 PM
DR_xB
Jul 20, 2004 08:31 PM
wonderworm
Nov 8, 2003 05:42 PM
