Sirius Problem
Old Nov 13, 2008 | 02:05 AM
VC-17's Avatar
Default Sirius Problem
I just installed Sirius Satellite in my Gen2 xB, I called and activated it and my stereo is telling me "NO Tuner" any idea what is wrong?
Old Nov 13, 2008 | 03:39 AM
AndreyCo's Avatar
maybe the tuner isn't plugged into the stereo?? lol
Old Nov 13, 2008 | 03:52 AM
VC-17's Avatar
I called Siruis, all was connected, however, the cable that connects the two units was loose and would not stay plugged in. I emailed TSS-Radio and told them about the problem, Sirius tech support told me the tuner can also be defective. Hopefully TSS-Radio will exchange both units for me. Thanks for the reply.
Old Nov 13, 2008 | 12:33 PM
VC-17's Avatar
Those of you who have installed this Sirius set up, The TOY-SC1 comes with a wiring harness that has 3 connectors, 1 plugs into the TOY-SC1 unit and there are 2 more connectors, I have to Basic Pioneer head unit and on the back of the unit there is room for only 1 connector, is the third connector from the harness for someyhing else or am I missing something?
Old Nov 13, 2008 | 01:39 PM
Slody4Futbol's Avatar
http://www.sirius.com/pdf/manuals/TOYSC1_userguide.pdf
there's your installation/user guide
it is a pigtail for factory harness that plugs into the same spot.. if you have a harness plugged into that spot then you remove it and plug it into the extra plug on your sc1
Old Nov 13, 2008 | 01:40 PM
and btw in the troubleshooting part of the guide it lists these problems for "NO TUNER"
Check for loose connections.
Check that connector alignment/orientation is correct.
Check that cables are not pinched or damaged.
Check that fuse is not blown.
Check that the factory XM module has been disconnected.
Check for incorrect connections, some vehicles may have similar aftermarket modules
installed that utilize the same type of connector.
Old Nov 13, 2008 | 08:21 PM
VC-17's Avatar
I appriciate all the replies and I did check all the above listed items, still no luck. I called TSS-Radio, they are sending me 2 new units to replace the ones I have. Talk about CUSTOMER SERVICE, wish there were more companies out there like this company. Once again, thanks to all, hope all works out when I receive and install the new units.
Old Nov 13, 2008 | 11:56 PM
cool.. yeah if you've checked everything then i would assume bad unit.. good luck and hope you fix the problem
Old Nov 20, 2008 | 12:22 PM
VC-17's Avatar
I received the new replacement units from TSS-Radio yesterday, installed the units and all is good now. It did turn out to be the interface cable and Tuner. TSS-Radio is great and has outstanding customer service.
RY_TC07
Jul 18, 2017 05:18 PM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
lunchbx05
Dec 11, 2014 06:13 PM
crocker
Dec 2, 2014 03:44 AM
