Help! My headlights stopped working
Old Nov 13, 2008 | 02:51 PM
JustynTime's Avatar
Default Help! My headlights stopped working
So last night all of a sudden my headlights stopped working. My daytime running lamps were on though and my high beams worked. This morning my day time lamps stopped working too. I cant imagine that all 4 bulbs blew out at the same time. I checked the fuses under the hood and they were all fine. I replaced them anyway and still the problem persists. What could it be? Did I really blow all 4 lights at the same time?
Old Nov 13, 2008 | 03:40 PM
ADRdesignCo's Avatar
tcs have dtrls? what did you replace? the bulbs or the fuses? check the connections, maybe it fell out or came loose or something.
Old Nov 13, 2008 | 03:45 PM
JustynTime's Avatar
I replaced the fuses. I cant imagine 4 different bulbs coming loose at the same time but I checked that too and they are fine.
There appears to be a fuse fro each side hi and each side low. I replaced all 4, no help.
Old Nov 13, 2008 | 06:06 PM
Astoria's Avatar
try that reset function. it details it in the manual but it has to do with holding the key in a certain position for like 30 seconds.
Old Nov 13, 2008 | 06:09 PM
JustynTime's Avatar
Ive heard of the reset when dealing with the power windows or the sunroof but I didnt know it had anything to do with the lights
Old Nov 14, 2008 | 06:55 AM
AcidDrop's Avatar
what type of bulbs where you using, if aftermarket then you probably fried the low beams and then the problem got worst and decided to fry everything else. also have your headlight housing gotten foggy or has anything spill over the wiring?
scsteven
Jan 25, 2015 01:06 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
LeChuck
Dec 9, 2014 02:26 AM
