The Truth - 440cc Injectors @ 8PSI? Maybe 9PSI?
Old Nov 13, 2008 | 06:33 PM
johnhawkins's Avatar
Default The Truth - 440cc Injectors @ 8PSI? Maybe 9PSI?
What is the truth? Will 440cc injectors work at 8-9 psi??? Greddy kit uses 440cc injectors at 8.5PSI? In previous threads, I couldnt find an answer. Any one????[/b]
Old Nov 13, 2008 | 07:49 PM
blown_xa's Avatar
Default Re: The Truth - 440cc Injectors @ 8PSI? Maybe 9PSI?
If you are running the complete GReddy turbo kit, you will hit close to 100% injector duty cylce at 9psi with their 440cc injectors. Hope this help.
Old Nov 13, 2008 | 07:51 PM
gompka's Avatar
I would say yes, many people running the 9.5psi supercharger pulley with the stock 440 cc injectors.
Old Nov 13, 2008 | 08:15 PM
xceptionalauto's Avatar
The injectors are more than maxed out. Will it work? Yes, for a while. If you had 275 crank hp, .65bsfc, 51 psi fuel pressure and 100% duty cycle with 4 injectors it would require 434cc injectors. Usually you want to have about 80-85% duty cycle. So I would say on the Greddy kit the injectors are running a little over what they should.
Old Nov 13, 2008 | 09:20 PM
jetlounge's Avatar
apples and oragnes
1) s/c does not come with "stock 440 cc injectors". try 410
2) 9.5 s/c != 9.5 psi t/c
Old Nov 13, 2008 | 09:24 PM
gompka's Avatar
apples and oragnes
thought i saw a post that said s/c injectors were 440. My mistake.
Why isn't 9.5psi s/c the same as 9.5psi t/c ? Pressure is pressure doesn't matter what it comes from, granted the s/c only hits that at redline i guess.
Old Nov 13, 2008 | 10:44 PM
05-RS1's Avatar
^^ i thought the stock S/C injectors were 440cc as well..
Old Nov 13, 2008 | 11:07 PM
Ace83's Avatar
Ronin Scion
yup on a greddy kit it will be good around 9 psi but will be maxed out or close.. maybe if you run a fuel pump it will give you some more room.. but that depends on your target WOT afr too.. if you run a bigger turbo you sure would be maxed out before 9 psi..
on my 550 injectors I have 89% duty cycle at 9 psi with afr of 11.0.. no fuel pump w/ a gt30 turbo
Old Nov 13, 2008 | 11:46 PM
jetlounge's Avatar
Common misconception. Plus they never updated the FAQ here, even though I told them.
http://blog.scionxtc.com/blogs/archi...n-xb-2008.aspx
and here on SL:
https://www.scionlife.com/forums/vie...ighlight=400cc
bingo
Old Nov 14, 2008 | 01:34 PM
CarbonXe's Avatar
apples and oragnes
The S/C does have 440cc injectors. You cannot compare 9.5psi on the S/C and 9.5psi on the turbo, it's completely different. PSI =/= CFM.
Old Nov 14, 2008 | 05:24 PM
jetlounge's Avatar
negative on the 440. Check the links above.
Old Nov 14, 2008 | 05:33 PM
CarbonXe's Avatar
Ahh, didn't know they were even smaller. Lol, you tore that tool a new _______. .
And according to Dezod, stockers are 320cc, not 370cc like you stated in your thread.
Regardless, they're too small for a turbo.
Old Nov 15, 2008 | 12:43 PM
Thank you everyone for your response.
I am running 2.5" Catless Exhaust, 2.5" FMIC Piping, JDM Sport Cast Manifold, JDM Sport Hybrid Turbo AR.50 if this helps. I will prob just run it at 8psi to be safe on the 440cc injectors. Should still be a noticable jump from the 6psi I am currently at!
Old Nov 15, 2008 | 09:59 PM
rhythmnsmoke's Avatar
Music City Scions
apples and oragnes
No, 9.5 PSI s/C != 9.5 PSI t/C. They don't make no where near the same amount of power, require different amount of fuel delivery. 440cc injectors on a 9.5 PSI tC would be reaching/reached max. That's not the case with the S/C'er though.
And yeah, my understanding is 440cc injectors with the S/C'er stock as well, guess not.
Old Nov 15, 2008 | 10:05 PM
Music City Scions
Originally Posted by CarbonXe
Ahh, didn't know they were even smaller. Lol, you tore that tool a new butthole. .
My understanding is they are 370cc not 320.
Old Nov 16, 2008 | 02:19 AM
highvoltage1's Avatar
I love JDM parts on a tC!!! ROFL
Old Nov 16, 2008 | 03:24 AM
dave2610's Avatar
jdm tc parts=ebay
Old Nov 16, 2008 | 06:05 AM
Joe_Dezod's Avatar
We flow tested them. 320cc.
Old Nov 16, 2008 | 06:15 AM
gompka's Avatar
so a turbo at 9.5 psi vs. supercharger at 9.5psi flows more air even though they are at the same pressure? Err anyone care to explain why this is so? They work the same way hence I would assume 9.5psi is 9.5psi, but someone please enlighten me...
Old Nov 16, 2008 | 09:08 AM
scionkidd's Avatar
my tC has the greddy kit and im injector limited at 8.9 PSI
