VIET_BOX
12-26-2004, 09:30 PM
I tired to search how to install taillights but i couldnt find any. Can someone help
View Full Version : How to install new tail lights VIET_BOX 12-26-2004, 09:30 PM I tired to search how to install taillights but i couldnt find any. Can someone help hotbox05 12-26-2004, 09:36 PM check the faq. but it is very easy . two or three nuts and then 3 lights hold em in then u just slide the housing out. Fujiz_xb 12-27-2004, 02:31 AM ok..there are two nuts you hve to remove. use a 10mm socket for the nuts. remove the panel on the side in the cargo room. locate the nuts with your fingers and carefully remove them. Unplug the harnes either before removing the nuts or afterwards. carefully remove the tail lights so you dont break an outer clips on the lights. its easy but be carefull. pm me if you need more help. squirrel 12-27-2004, 02:50 AM ok..there are two nuts you hve to remove. use a 10mm socket for the nuts. remove the panel on the side in the cargo room. locate the nuts with your fingers and carefully remove them. Unplug the harnes either before removing the nuts or afterwards. carefully remove the tail lights so you dont break an outer clips on the lights. its easy but be carefull. pm me if you need more help. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Yup, just two 10 mm nuts on each side. Should take no more than 30 minutes to change out both sides. I work slow. Fujiz_xb 12-27-2004, 03:05 AM try changing them in freezing 30 and below weather with high winds....but it was worth in in the end with my new TYC's jwbowen21 12-27-2004, 03:20 AM i changed mine in freezing weather too, and it was way worth it when i noticed the diffference the TYC's make in the looks of the tail end of my xB. 05camoxb 12-27-2004, 04:25 AM recently changed mine too.. however it took me awhile since the upper nut is in a really cramped space.. but it was worth the trouble seein my box with tyc's. good luck viet. 12-27-2004, 03:21 PM Just changed mine as well. :D http://www.precisionmuffler.com/3c5108c0.jpg Munch 12-27-2004, 03:31 PM Sweet 8) Stylis randode 12-27-2004, 03:54 PM Just changed mine as well. :D http://www.precisionmuffler.com/3c5108c0.jpg whaaaaaaat? did you vinyl those? i kinda like it. :D 12-27-2004, 04:08 PM whaaaaaaat? did you vinyl those? i kinda like it. :D Those are the Blue Batmobile overlays and I chopped them up to fit that way. the Opr8r sent me a pic of a bB from japan that had the same tailights and I had to have them. Or make them. :D Fujiz_xb 12-27-2004, 04:20 PM nice tailights stylis. makes my NEW tyc's look like chumps 12-27-2004, 04:39 PM :lol: Don't say that. VIET_BOX 12-27-2004, 07:21 PM any tips on getting the top screw off? I cant seem to take it out. Fujiz_xb 12-27-2004, 08:26 PM its all in the writst. no actual tip..just play around with it. one turn at a time. squirrel 12-27-2004, 08:31 PM any tips on getting the top screw off? I cant seem to take it out. I think I had to use a universal joint w/ the short 10 mm socket to get the nut off. Man, I'm way too old to remember now. Or did I just use a stubby 10 mm wrench? hotbox05 12-27-2004, 08:35 PM i used a reg 10mm socket with my gear ratchet. |
