Anyone have a "trunk" release in their tC?
Old Dec 27, 2004 | 08:16 AM
ProjectD's Avatar
Default Anyone have a "trunk" release in their tC?
I'm thinking about getting one. Would they work on a tC? Also, do they open up just a little or do they open up all the way. If they open up all the way, I'll definitely get one.
Old Dec 27, 2004 | 07:06 PM
scion_tC's Avatar
it's a hatchback, getting a trunk release would be like carrying oxygen tanks, it makes no sense. If you ever get locked in your trunk, climb to the back seat, then the front and open the door... :D
Old Dec 27, 2004 | 07:23 PM
eclipxe's Avatar
w...t...f?
Old Dec 27, 2004 | 08:09 PM
bahamut_zero's Avatar
I think they mean a way to open the hatch automatically from the outside. Press a button and it rises. I dunno...
Old Dec 27, 2004 | 08:20 PM
ltj42884's Avatar
maybe a button in the glovebox that you push and it pops the hatch is what he means
Old Dec 27, 2004 | 08:39 PM
f00dstamps's Avatar
he means a trunk release that allows remote trigger of the trunk.
i.e. you're carrying groceries and instead of fumbling around putting the key in the hole, you press a button that triggers the trunk to release. now, all you have to do is pull it open.
this is often an option with alarms
Old Dec 27, 2004 | 08:42 PM
ProjectD's Avatar
that's exactly what I meant. I wanted to know that if I got a trunk release for my Viper 791xv, will it function correctly. I thought it'd be pretty cool if i was walking to my car from like the supermarket and press a button and the hatch lifts up. It would be cool but still practical.
Old Dec 27, 2004 | 08:50 PM
f00dstamps's Avatar
project,
i know it's possible with your alarm but i'm not sure what you need. it might hook up directly to the alarm or you might need a trunk release relay. i wont' even have my TC until tuesday so i don't even know yet. if you have to pull a latch to open the trunk, you'll need a solenoid. if it's an electrical push button, you will only need a trigger since there will already be a solenoid installed.
did you install your own alarm?
i plan on doing the same alarm install or the clifford matrix 3.5 which is the same alarm.
Old Dec 27, 2004 | 09:22 PM
komik's Avatar
DeepSouth Scions
I don't think that it would function very well. You would probably have to install a motor to raise the trunk enough for the shocks to open it all the way. I believe the hatch is too heavy to just pop up easily.
My friends BMW has a trunk release on the key that essentially serves the same purpose as the button underneath the trunk handle. It releases the grips on the hatch (or trunk in the BMW's case), but you still have to manually raise it.
Old Dec 27, 2004 | 09:26 PM
ProjectD's Avatar
thanks for all the replies. I think I'm gonna pass on the trunk release
Old Dec 28, 2004 | 01:21 AM
rolstc's Avatar
with the alarm system that i have .... my remote features a feature like that. Where i hit the button the trunk opens
Old Dec 28, 2004 | 07:17 PM
komik's Avatar
DeepSouth Scions
How wide does it open?
Old Dec 28, 2004 | 07:26 PM
rolstc's Avatar
half way
Old Dec 28, 2004 | 07:30 PM
komik's Avatar
DeepSouth Scions
Then I stand corrected.
Old Dec 28, 2004 | 07:40 PM
rolstc's Avatar
yeah put its due to the hyrdaulic pumps. if i put some sort of lube or something on it like my KY Jelly that i keep in my drawer i bet it would go all the way up ... OOPS did i say that outloud
Old Dec 28, 2004 | 10:45 PM
iowagary's Avatar
That would be good to have for the trunk monkey and all. Right now he'd have to like... push the hatch open or something.
Old Dec 28, 2004 | 10:59 PM
sciontc_mich's Avatar
so im not alone in the hatch having to be helped up?
Old Dec 29, 2004 | 05:37 PM
Mudd's Avatar
It's a one-wire hookup for the alarm. Mine's got it.
It's about stupid though, just because all it does it pop it. You still have to pull the hatch open, and you may as well just press the hatch button to do it.. I just did it for a while-I'm-in-there thing when I was installing the alarm.
Old Dec 29, 2004 | 05:57 PM
iowagary's Avatar
Right... you can't remotely pop the hatch and have it actually open unless you installed some servos or something. In warm weather, a little push and it will open itself (but it still needs the push). Especially in the cold, those hydraulic cylindars don't work so good so it seems to need extra help - pretty standard. Fine with me. When it opens all on it's own, it usually hits the bolts on my garage door... *cringe*
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
xBrelease08
Sep 13, 2015 04:39 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
umnitza
Sep 1, 2015 08:06 PM
