wastegate question
Old Nov 25, 2008 | 01:37 AM
Manch's Avatar
Default wastegate question
i have a wastegate with out a spring. is it possible to get a 5-7psi spring and run about 9psi without any problems?
Old Nov 25, 2008 | 02:08 AM
draxcaliber's Avatar
well...since the spring is what regulates the boost...i'd guess no, maybe you could contact the company that makes it and order one?
Old Nov 25, 2008 | 02:23 AM
ScionizedRide's Avatar
which wg?
Old Nov 25, 2008 | 02:39 AM
thendawg's Avatar
yea just get a 5 or 7 psi spring and a manual boost controller - the wastegate spring will define the MINIMUM boost you can run, you can run higher than that by adjusting the boost controller - as a rule of thumb you dont want to adjust much higher than 2x what the spring is set for - so with a 7 psi spring you wouldnt want to adjust your mbc above 14 psi
**EDITED SO IT MAKES SINCE I CANT TYPE**
Old Nov 25, 2008 | 02:45 AM
SVicksTC's Avatar
Originally Posted by thendawg
yea just get a 5 or 7 psi spring and a manual boost controller - the wastegate spring will define the MINIMUM boost you can run higher than that by adjusting the boost controller - as a rule of thumb you dont want to adjust much higher than 2x what the spring is set for - so with a 7 psi spring you wouldnt want to adjust your mbc above 14 psi
Qouted for the Truth.....That about sums it all up
Old Nov 25, 2008 | 03:17 AM
^yea but if he has an internal one, i dont think he can just change the spring
Old Nov 25, 2008 | 03:51 AM
SVicksTC's Avatar
ahhh very good point didnt even think of that
Old Nov 25, 2008 | 01:36 PM
thendawg's Avatar
If he has internal just put an mbc on the internal wg - only thing is whatever the internal wastegate is thatll be the lowest boost you can run
Old Nov 27, 2008 | 01:27 AM
olaHalo's Avatar
haha
the minimum isnt defined by the wastegate
the wastegate defines the max amount of boost without a boost controller
for example if i had a 5 psi spring, i wont start at 5 psi and move up
i'd move up to a max of 5 psi
Old Nov 27, 2008 | 04:28 AM
highvoltage1's Avatar
Yea i was like what did he say. Good job Ola!
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
