Sonar headlight wiring diagram/walkthough needed!
Searched my but off and did not find much. I guess for the most part its just plug and play right?
However what about the Halo's?
How do i get them to come on with the parking/running lights?
__________________
__________________
Its easy your parking/turn signal harness has 3 wires (diff each side)
LH side
1. white w/black stripe = ground (hook to black wire on halo's)
2. solid green = parking light
3. green w/black stripe = turn signal
RH side
2. green w/orange stripe = parking
3. green w/yellow stripe = turn signal
you just have to choose weather you want them to come on with parking light or maybe use the inside one as parking and have the outside one wired to come on with blinker. (this is where you will hook the red wire from halo's)
Hope this helps
LH side
RH side
Hope this helps
LH side
RH side
Hope this helps
LH side
RH side
Hope this helps
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
rancur3p1c
Dec 19, 2014 04:30 PM
