jocappy
12-28-2004, 12:03 AM
I am getting 17s for my xB with 215/40R17 tires. Just wondering what type of drop I should do, so I dont need a camber kit. Just springs. And brand name of the springs I should use. Thanks, Joe
View Full Version : xB lowering question please help ;) jocappy 12-28-2004, 12:03 AM I am getting 17s for my xB with 215/40R17 tires. Just wondering what type of drop I should do, so I dont need a camber kit. Just springs. And brand name of the springs I should use. Thanks, Joe rollotomassi 12-28-2004, 12:09 AM I'm running a set of Goldlines (2" drop F & R) and have run my 17's w Goodyear F1s 215/40/17 for about 3000 miles with no camber kit. I have seen no abnormal tire wear. Just my 2 cents. 8) Yoshii 12-28-2004, 12:13 AM on my ride...i am running Sprint springs 2' drop and running on 19's and no problems...very nice ride for me...i have had them on for around 1 year and 7 months...and they are still good. squirrel 12-28-2004, 01:02 AM I am getting 17s for my xB with 215/40R17 tires. Just wondering what type of drop I should do, so I dont need a camber kit. Just springs. And brand name of the springs I should use. Thanks, Joe I have the same size tire on 17x7.5 wheels w/ 42 offset on a 2.5 inch drop. You will not need a camber kit, but you will need 3 mm spacers in the rear. Depending on the offset, you will prolly need spacers in the rear. Prior I had 205/40-17, on 7 inch wide wheels w/ 40 offset on 2 inch drop and no rubbing either. rollotomassi 12-28-2004, 01:06 AM That's true about the spacers- good point. I forgot to mention I'm running +42 offset on 7.5 width rims & I installed 10mm OneTonGarage HUB spacers in the rear. Install was super easy- took 20 minutes & cost $60- I highly recommend! 8) http://www.onetongarage.com/ Nice to deal with.... TrophyWHORE 12-28-2004, 01:20 AM GoldLine 2" Drop springs with 18" Rims here Recomend spacers too silkywilson 12-28-2004, 02:03 AM 2" goldlines, 18X7.5 wheels 215/35/18 and one ton garage rear spacers.. didnt rub with or without the spacers and I think immat 42 offset.. TheScionicMan 12-28-2004, 03:29 AM I'm running the GoldLines too with a 17x7 wheel +40 offset and 215/40s too. And have the OTG rear spacer shim. Didn't need them for rubbing issues, just for looks... rollotomassi 12-28-2004, 03:48 AM Alot of us running Goldlines..... 8) jocappy 12-28-2004, 05:56 AM The wheels I am getting have a 40 offset. Will I need shims, key word being NEED. Or do I want them for looks? Joe hotbox05 12-28-2004, 10:16 AM want EVILDAVE 12-28-2004, 02:15 PM The wheels I am getting have a 40 offset. Will I need shims, key word being NEED. Or do I want them for looks? JoeI'm running 18" with a 42 offset and 2" drop Goldlines with no problems but you might want to get the 10mm one ton garage spacers to pull your back wheels out flush with the fronts. jocappy 12-28-2004, 02:18 PM The wheels I am getting have a 40 offset. Will I need shims, key word being NEED. Or do I want them for looks? JoeI'm running 18" with a 42 offset and 2" drop Goldlines with no problems but you might want to get the 10mm one tog garage spacers to pull your back wheels out flush with the fronts. What are "10mm one tog garage spacers"? EVILDAVE 12-28-2004, 02:22 PM The wheels I am getting have a 40 offset. Will I need shims, key word being NEED. Or do I want them for looks? JoeI'm running 18" with a 42 offset and 2" drop Goldlines with no problems but you might want to get the 10mm one tog garage spacers to pull your back wheels out flush with the fronts. What are "10mm one tog garage spacers"?Sorry fixed it check out this web site www.onetongarage.com randode 12-28-2004, 03:05 PM The wheels I am getting have a 40 offset. Will I need shims, key word being NEED. Or do I want them for looks? Joe with 40mm offset, you wont need spacers. They do make it look better though. I recommend 215/40/17 tires and GoldLine 2" springs. I have lowered over 40 Scions and most of them are on GoldLines. I have also replaced a lot of other (Sprint, TRD, etc.) springs with GoldLines. They are high quality, and ride better than stock. squirrel 12-28-2004, 04:34 PM It depends on how wide your wheels are. On a 40 offset, if its a 7.5 inch wide, you may need a 3 mm spacer, but if its a 7 inch wide wheel, you may not. xbox83 12-28-2004, 07:18 PM where would you buy wheel spacers at just as a general question on the topic TheScionicMan 12-28-2004, 07:22 PM The same place as the rear spacer shims - www.onetongarage.com - http://www.onetongarage.com/products/wheel_spacer/index.html richdog 12-28-2004, 11:35 PM goldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldlinegoldline Talk to scionspecialistvegas.......Talk to Bill Turner. 12-29-2004, 12:29 AM I am RS*R springs and the ride is comfortable, the cornering is perfect and my wheels look great , being complimented by the drop. squirrel 12-29-2004, 02:49 AM I am getting 17s for my xB with 215/40R17 tires. Just wondering what type of drop I should do, so I dont need a camber kit. Just springs. And brand name of the springs I should use. Thanks, Joe Joe as far as springs are concerned, Goldlines! Ask Mark (thescionicman) to post a pic of his camo xB. jocappy 12-29-2004, 04:27 AM The same place as the rear spacer shims - www.onetongarage.com - http://www.onetongarage.com/products/wheel_spacer/index.html POST A PIC OF THE CAMO WITH GOLDLINES;) richdog 12-30-2004, 01:45 AM Check out my profile I have goldlines. Very nice look and corners like it's on rails. 12-31-2004, 09:15 PM The RS*Rs are a nice premium spring also, great drop and a perfect rake. :D |
