View Full Version : '04 xB 1st Gen and excessive engine oil use
Ford_Falcon
11-30-2008, 08:22 PM
Hey peeps,
I have an '04 xB and I'm pretty religious when it comes to changing the engine oil regularly. I have only been using Mobil 1 and change it out about every 5K miles. Since the last 2 changes however, I'm noticing the car is using more oil than usual. I had to top it up just recently, before the time I usually replace it. There are no drops on the floor, so I know it's not leaking. It has around 115K miles on it. I change the spark plugs annually.
Has anyone had a similar issue? I am sure it is just normal wear and tear. Just wondering if this is about the time the heads need to get cleaned and new gaskets fitted, or if something else needs looking at, like the timing?
Thanks,
Dave
Reactor
11-30-2008, 08:39 PM
I've seen these engines last 300K without any exessive oil use (in Toyota Echo).
Timing is not going to have anything to do with oil, besides it's not adjustable anyway.
Try to find out where the oil goes if it's not leakng. Look for signes of it getting into cylinders by checking appearence of spark plugs or even looking inside the cylinders. In case the piston rings are worn out you may have some oil inside the intake manifold because of the blow-by.
jct
11-30-2008, 09:18 PM
have you replaced the PCV valve lately?
365Motorwerks
12-01-2008, 05:47 PM
I did and you can see it here.. http://www.youtube.com/watch?v=vAbGydNgaYk :P
It is easy to pop off the hose going into the intake manifold and the one by the MAF and see if there is a bunch of oil there.
VIP_CAMO
12-02-2008, 07:21 AM
he's got miles on his box to so he would be one to answer ...
Ford_Falcon
12-02-2008, 07:35 AM
Hey guys, thanks for the replies. No, I have not replaced the PCV valve. I will do that next and give you an update. I will check the plugs too, just to be sure I'm not missing any internal leaks.
Cinderblock
12-04-2008, 05:03 AM
hey zack, how many miles did you have when you changed pcv? what about the big a$$ hose that goes from the other cam cover, um bump thingy, into the mani. could he excessive blowby from that?
365Motorwerks
12-04-2008, 05:11 AM
I don't remember maybe 150,000? It still rattled when I shook it and was probably fine but they are only $8 or so. The other hose is just a crankcase vent and goes right from the valve cover to the intake manifold with no check valve at all. Both of my hoses had a good amount of oil in them but I never had a loss on the dipstick between oil changes. BTW other people I have asked with around 50-60K say that those hoses have no oil on them. Lets see how those plugs look.
Ford_Falcon
12-04-2008, 08:01 AM
I ordered the positive crank case ventilation valve today. Should have it by friday. Will replace and check plugs then, as well as the air filter and hoses for oil leaks.
For those new to the blowby term, here is some information on it: http://www.misterfixit.com/blow-by.htm
Cinderblock
12-05-2008, 03:01 PM
mine both have oil, with no loss to report either. weird
jct
12-05-2008, 04:44 PM
i replace my pcv every year even though it doesn't need it i still do it anyways
Ford_Falcon
12-05-2008, 04:59 PM
Update:
I'm still waiting for the PCV but in the mean time I did remove the manifold cover and take a look at the existing one. As soon as I removed the PCV hose I noticed oil on the end of the valve. I unscrewed it and shook it and it rattles quite convincingly. I also removed the hose that is positioned on the manifold, forward of the PCV valve hose, and it too has oil in it.
So, do I also need to get the intake manifold cleaned?
Just a side note, a couple of months ago, I removed the plastic hosing that sits forward of the air filter. Could this also be related to the problem?
365Motorwerks
12-05-2008, 05:49 PM
If this is the one (and even if it's not) that goes from the air box to under the headlight to draw in air it has no effect.that
firesquare
12-06-2008, 03:52 AM
mine is doing the same. burns a 1/4 every 5K. ill have to do a PCV valve also. Toyota plugs are recommended every 30K. my car stumbles hard after 30K
Ford_Falcon
01-21-2009, 05:54 PM
Well,
I replaced the PCV valve, and I no longer have a problem with the oil.
Good to go!
HeathenBrewing
01-21-2009, 06:54 PM
.... soon as I removed the PCV hose I noticed oil on the end of the valve. I unscrewed it and shook it and it rattles quite convincingly.....
Well,
Good to go!
This goes to show that old myths die hard. Millions of owners think that if a PCV valve rattles when shaken that it is okay. Wrong!
Just because it rattles doesn't mean its calibrated spring is metering correctly. Cleaning the PCV doesn't accomplish any thing either. A PCV valve should never be cleaned and placed back into service. Cleaning a PCV valve will result in a clean PCV valve; not a new PCV valve.
There are contaminants that will remain in the PCV valve that can never be flushed out. Additionally, there is an amount of wear that will be experienced by the spring that cleaning cannot replace.
365Motorwerks
01-21-2009, 06:58 PM
Well,
Good to go!
Great to hear it was something that easy!
jct
01-21-2009, 07:12 PM
i like preventive maintenance
i'm glad it cured your problem :)
Ford_Falcon
01-30-2009, 06:29 PM
Thanks guys,
I'm glad I found this forum to be so helpful with suggestions. You guys rock!
Cinderblock
01-30-2009, 08:24 PM
nice, i should check mine out, its about that time i think, and then put a catch can on that line, because the other line people put a can on doesnt put out any oil vapor like hardly at all lol.
B2FiNiTY
02-01-2009, 07:33 PM
That's not even that much oil but always good idea to catch it early.
Ford_Falcon
05-29-2011, 05:31 AM
Hey guys, I know I started this thread a couple years ago, and I stumbled upon it again today while searching my subscribed threads. Anyway, another 'source' of the oil loss I had, believe it or not, was a worn crank position sensor seal! I took it to Toyota a couple of weeks ago and they showed me a trail of oil that went from the sensor through the harness, to the ECU. I couldn't believe it either, but the guy pulled the ECU out, and sure enough, there was oil on the connectors. I've since replaced the O-ring on the sensor, next step is to get the ECU and harness cleaned.
Ford_Falcon
10-02-2011, 04:53 AM
Well, I went through a couple of O-rings and it still leaks. I bought a set of automotive o-rings of different diameters thinking one of them should do the trick. I wanted to try that before forking over for a replacement crank position sensor. I might just have to do that now...
jbod
10-03-2011, 04:06 AM
you got a lot of miles on that don't you? 200k+ plus right?
Ford_Falcon
01-21-2012, 09:49 PM
I do. Around 220k now. No oil on the end of the PCV, but oil in the intake and return air hose. I'm gonna have to replace the piston rings.
mrsocks
02-07-2012, 12:16 PM
I gotta say "Thanks" too (albeit a bit in advance). My "box" has 65k on it and I've changed the oil 19 or 20 times (always synthetic and with Purolator I filter). Goin 5 grand with any oil scares me! Anyway, I always pour out just about 4 qts american of the old stuff except for the last time when it was about 3 1/2 qts. No leaks anywhere and if it smoked, the windows are so damned dark that I wouldn't see it anyhow. I'm gonna get a PCV valve today just for yuks and see what happens the next 3k or so. By the way, the 30k plug change seems (or feels) too long to me also. The last 5 or 10k is sluggish compared to how it feels after new (stock) plugs. 20k next time.
Thanks to ALL!!
Socks
firesquare
02-07-2012, 02:23 PM
their is no harm in doing things too early but all the manufactures suggested intervals are fine also. 5000 miles is not long for an oil change now. especially with synthetic. don't burn your money away. plug's at 30 are normal as well.
