What to look for in Coilovers
Old Dec 2, 2008 | 07:33 PM
TuningIsLife's Avatar
Default What to look for in Coilovers
Just out of curiosity,
What do you guys look for in your coilovers and why? i.e. Track, AutoX, Street, Daily Driven, quality, handling, lowness factors, etc.
Old Dec 2, 2008 | 08:10 PM
burstaneurysm's Avatar
A lot of people are looking for coilovers that drop them low while retaining street comfort. The Progress are good for this.
Old Dec 2, 2008 | 09:00 PM
1epoXyBox's Avatar
I bought mine to go low and improve suspension performance. Although the comfort factor disappears, but I anticipated that. Its a daily driver, a little bumpy, but still fun. Ksports
Old Dec 5, 2008 | 04:27 AM
stenger's Avatar
Then you need to tweak you're settings.
D2's, Had them for auto-x, and road course. High pre-load on REAL tracks, with full firm damping. 1/2 way firm/soft with mild pre-load on daily driving. and mild springs rates, 3/4 full firm for auto x. Also have other goodies to help me turn as well.
I'd stay away from Progress. Not that they are garbage, because they are not. But because you only get height and damping adjustment. Its best to be able to adjust height, with out changing your spring rates. It'll provide for a better all around ride, less noise, and better handling. Also D2-KSport-Tien-STD-Cusco all come with Pillow block mounts up front, with camber adjustment. Camber adjustment is you're best friend when you're running low offset wheels, or track.
Old Dec 5, 2008 | 06:41 AM
1epoXyBox's Avatar
The only adjustments I have are the height, dampening, and camber on the front struts. Right now I am running the dampening at full soft, and the camber is all the way over (negitive). What other adjustments would you suggest?
Also, what else are you using to improve suspension/cornering. I would love to get the box to corner as best it can.
Right now I have front strut bar, and rear sway besides the ksports.
Old Dec 5, 2008 | 10:02 PM
365Motorwerks's Avatar
Next step would be to swap out the endlink and front sway bushings for polys (it's like $25 and easy enough!) after that front control arm and rear trailing arm bushings as well. If you don't have a set of axle spacers and if your rear wheels allow clearance wise that will give you a little extra stance out back. Don't forget tires as well! A cheap set will make all the suspension upgrades feel like crap and you'll wonder where your hard earned cash went!
Btw I had somebody go from springs to Progress Coilovers then to KW and the comment was on how awesome the KW's rode and actually handled the obstacles like potholes and bumps, not too stiff and definetly not mushy or bouncy! Costs more I know but you get what you pay for in alot of cases!
Old Dec 6, 2008 | 03:14 AM
Cinderblock's Avatar
i made a swaybar for the rear of my box , i was going to make more for my club, but i still need the right sized peice for our tube bender. that thing turns nice tho with that. i can get slight oversteer. but it will lower you rcomfort values over steeper driveways, cuz it ll 3-wheel like nones business haha, i get people givin me WTF!? looks when that inside wheel comes off the ground. i like my tien ss+p's, i just with their was a little more adjusment, the dampning is fine, but the rebound adjusts with it, and its to hard, if i hit a bump itll take the intial shock like a champ, but then it bounes back kinda harsh, im used to it and have compensated for it.
Old Dec 6, 2008 | 03:24 AM
firesquare's Avatar
<--loves 3 wheel madness
Old Dec 6, 2008 | 02:36 PM
I have a good transition from the road up a steep driveway to the shop it 3-wheels everytime too!
Old Dec 7, 2008 | 01:30 AM
3 wheel is fun haha, when i was at the crown scion auto x day last year, i helped build a sway for my friends car too, and our cars were picking up the inside tires in the tighter turns, and getting a little bit of smoke on the rear tires in the longer sweeping turn, it was cool lol. what is it with shops and driveways though?
Old Dec 8, 2008 | 05:53 AM
SoundBox's Avatar
Progress Tech.
Old Dec 15, 2008 | 06:59 PM
ippskidder's Avatar
1UP Crew
I like my megans.
Great for track usage and hard/fast turning.
On the softest settings it does pretty well with pot holes and bumps, but tends to sway slightly.
On the stiffest setting, going over a pothole or bump is a little harsh. It takes some getting use to. But no swaying.
I have it on the half way setting between soft/hard dampening.
Lowers pretty good on the front/rear. Rear can't be super tucked due to the way its made.
I might be selling these soon to upgrade to teins w/ edfc.
Old Dec 22, 2008 | 01:32 PM
brownfaux's Avatar
Utah Scions
my problem is no one near me has a set of coilovers on their xb, in utah. All I have to compare is my DF210's on 17's with stock shocks.
I guess my question is we all seem to know how the DF210's ride on stock shocks, so would i be better or worse off just getting the Progress Coils for 700?
http://www.corsportusa.com/store/cat...oducts_id=2980
Old Dec 22, 2008 | 01:36 PM
ippskidder's Avatar
1UP Crew
I read progress coils are pretty good.
I think ptuning.com sells them.
They might be able to give you some more insight.
greytc
Oct 26, 2015 07:53 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
rmz489
Sep 16, 2015 08:19 PM
ScionDP
Sep 8, 2015 02:17 AM
