S/C 11.5psi Injector size, once and for all!
Old Dec 10, 2008 | 06:29 AM
gompka's Avatar
Default S/C 11.5psi Injector size, once and for all!
So I have asked like 10 different people about this and received about 8 different answers....
The setup:
supercharger @ 11.5psi
a/w intercooler = minimal loss lets say engine will see 11psi
aem fi/c
What size injectors do I need...... Also for some of those recommending very large 700cc injectors I am worried that I will have trouble with idle. All those with experience please post results. Anyone know what size Icenine was running when he did the 311whp?
Old Dec 10, 2008 | 01:26 PM
m6ar2cel6oTC's Avatar
550cc! i had the trd supercharger with 12 psi pulley and i used 550cc. but i wouldnt reach 12 i would reach 11 psi
Old Dec 10, 2008 | 02:57 PM
g2autosports's Avatar
Nice set-up you got there m6ar2cel6oTC
Old Dec 10, 2008 | 03:20 PM
paul_dezod's Avatar
Scionetics
KAD
For 11 PSI on the S/C I would recommend 700cc. At this point, you are nearly identical to what Dan Gardner runs in his road race tC.
Old Dec 10, 2008 | 05:44 PM
gompka's Avatar
Not that i don't think you guys know what your doing, but why such big injectors with so little hp? I mean you have 800rwhp supras running 800cc injectors. Seems like overkill, maybe i'm just not understanding it properly. I did try to use the online calculators and all of them tell be between 600-700cc but what is the reason? Is it because of the amount of boost? Seems like turbo guys make much more power on smaller injectors. Thanks in advance!
Old Dec 10, 2008 | 05:49 PM
draxcaliber's Avatar
you need the bigger injectors because you need the extra fuel to help cool the engine while it evaporates depending on the efficiency of the a/w intercooler.
Old Dec 10, 2008 | 05:54 PM
gompka's Avatar
That makes sense, I guess I never thought of fuel as a cooling agent, always thought its sole purpose is for combustion.
Old Dec 10, 2008 | 06:09 PM
paul_dezod's Avatar
Scionetics
KAD
Duty cycles, the conservative nature of the tune, the amount of fuel needed to keep det down, fuel pressure, IC and effeceincy of it all will help in this dictation of injector size.
Old Dec 10, 2008 | 06:16 PM
lol thanks custom work is a pain but my car is running good with the custom turbo (wanna sponsor )
Old Dec 10, 2008 | 08:12 PM
kikcaffine's Avatar
550's
Old Dec 11, 2008 | 12:09 AM
BoostedBeastBox's Avatar
^ x2
Old Dec 11, 2008 | 01:40 AM
HEYitzMEEE's Avatar
Those 800hp supras have 6 injectors. We only have 4 lol. They can run those injectors cause they have 2 more to compensate what we dont have.
Old Dec 11, 2008 | 02:04 AM
jetlounge's Avatar
you can also check duty cycle
Old Dec 11, 2008 | 02:41 AM
jjos1's Avatar
I would say get 700cc what would they be another $50-$75 more than the 550's worth it to me, plus if you ever need more fuel down the line you have it.
Old Dec 11, 2008 | 03:48 AM
gompka's Avatar
yes but they also have .6 extra liters of displacement thats 25% more displacement than our engines.
Looks like 700cc is in the lead. I have no problems with getting the 700s but no one has commented on how the car runs with these while idle/not in boost thats the only thing i'm worried about at this point.
Old Dec 11, 2008 | 05:19 AM
kikcaffine's Avatar
Idle like absolute ____. It seems to be like the 700cc's are a way of over compensating for a lack of being able to tune properly.
Old Dec 11, 2008 | 05:21 AM
HEYitzMEEE's Avatar
^x2. People boosting making 350+ are using 700's. 550 almost sounds like the absolute max for 280 hp. if not a little more.
Old Dec 11, 2008 | 11:26 AM
jetlounge's Avatar
I had the same questions you did, but aside from the anecdotal 'can never go too big', 'go to xxxCC because this guy did', or '550 seems like the max' or 'just add fuel for cooling' was BS. I like to know the science of the application, just like you.
1. Check your actual injector duty cycles before guessing on the intertubes. We don't know if we're maxed until we test.
2. You are right, going huge when you don't need to is not efficient.
3. Fuel pump upgrade?
4. Have heard from several tuners (not internet tuners) that the 'cooling' effect from additional fuel is not as substantial as you think. I was told that it is a weak way to 'tune'. See #1.
5. Ok, so your first stop on this process, comparing other setups...forget the Supra..Let's just talk Turbo tC. You'll probably scratch your head wondering why the Greddy kit comes with 440cc injectors for mid-high 200whp setup. They seem to know what their doing right? So shouldn't that be the same for the s/c?
Not saying Greddy is perfect, and even here apples <> oranges. Here's why:
Always remember that the S/C needs belt driven power to make power. If you factor in even just 20% (that's a guess, don't believe me), then do the math. For a comparably equipped Turbo setup putting down 280 to the wheels, the S/C would have to be putting down MUCH more at the crank.
Old Dec 11, 2008 | 03:23 PM
gompka's Avatar
Exactly the answer I was looking for, I hadn't even considered parasitic loss in the equation. So the question that still remains is how will my car idle with the 700cc injectors? If the answer to that is bad then looks like i will have to look into either a 10.5psi pulley or sticking with my 9.5 and the a/w intercooler setup.
Old Dec 11, 2008 | 07:26 PM
Icenine ran 570cc's on the 12psi pulley to answer your other question. btw, if you deside to go with 10.5psi, i have the pulley&belt for sale.
