Vacuum Line - EVAP - PROBLEM - Clicking from Switch Valve??
Old Dec 10, 2008 | 09:13 PM
johnhawkins's Avatar
Default Vacuum Line - EVAP - PROBLEM - Clicking from Switch Valve??
I have had my tC turboed for going on 2 years now - I have always had some what of a "clicking" or "clanking" noise when at idle coming directly from the EVAP Switching Valve. Any one have any advice on this? - I want to fix it (finally) and I am wondering if the valve itself could be broken or if the vacuum block that is tapped inbetween there could maybe be causing this????? There are no other leaks in the piping or any other vacuum leaks. The "clicking" seems to travel to my boost gauge and sends the gauge boucing around a little bit . Any help is appreciated!
P.S. It seems to be acting up more now that I welded up a new down pipe that is only maybe 3 feet long (shoots out just past the pil pan & sounds amazing!!!)
Old Dec 10, 2008 | 09:37 PM
crush02342002's Avatar
that sound is normal i think.......unless its gotten louder then maybe somethings up....i normally hear my injectors more than anything els.
Old Dec 10, 2008 | 10:34 PM
hmmm i hate it - it only has gotten louder and more vicious since i put the short down pipe on - i might just replace the vacuum switch and see what hapens its only like $50
Old Dec 10, 2008 | 11:00 PM
let us know if it fixes it, im a little curious what could have made it go bad if indeed it is bad.
deathbyc4's Avatar
the clicking is normal, you just have to mount it to something less dense like rubber since it used to be mounted to the stock airbox.
Old Dec 10, 2008 | 11:06 PM
is it possible that higher pressure levels due to boost could lead to it sounding louder or even eff it up? Im just wondering.
Old Dec 10, 2008 | 11:13 PM
dave2610's Avatar
i get a clicking noises at idle as well havent pinpointed where its coming from yet sounds like under the dash somewere
Old Dec 11, 2008 | 01:48 AM
HEYitzMEEE's Avatar
Well I have broken valve shims that you can hear on the freeway. Be glad it's your switch and not your valve haha.
Old Dec 11, 2008 | 01:51 AM
are you sure its shims?
Old Dec 11, 2008 | 01:54 AM
HEYitzMEEE's Avatar
Not 100% sure, gompka had the same problem where it sounds like a typewriter clacking (same noise I have) but his wasn't as loud as mine. He ended up getting him shims replaced and it went away.
Old Dec 11, 2008 | 02:06 AM
hmmmm...well i left some info i found on your thread
Old Dec 11, 2008 | 01:20 PM
I had that same "typwriter" noise coming from the belt,pully,block area. Its has since gone away after installing the nex belt and removed A/C
my06tc
Jun 25, 2015 12:18 AM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
AdmirN
Jan 5, 2015 10:19 PM
carid
Nov 21, 2014 11:00 AM
Phillip_Injen
53
Jan 17, 2004 01:56 AM
