LIfe with a Turbo
where can u get sc for cheap? u mean a universal centrifugal? yeah i've been wanting to toy around with those on previous cars. ( i am for sure doingh it with my bmw 320i) i unno alotta fabbin and such pluse custom fuel management and the likes. if u have the resources do it. i'm sure we'd all love a how to on building f/i for under 1500
They have those superchargers on ebay and stuff like that. They dont cost more than about 200, but I don't know how good they are. It says 250 cfm at at 6000 rpm's (about 10- 15 hp gain. Go to ebay and type in scion supercharger). And if you were to get an expensive turbo, how much hp is 6 psi... also 7 psi.
any ELECTRIC powered turbine for your car will be highly inefficient, because it depends on your car's alternator to supply the power needed to turn it, meaning more load on your engine.
remember, energy can neither be created or destroyed. it can only be converted into different forms of energy.
you cannot create HP from nothing.
oh, btw, i realize that this topic is a bit touchy, for some cars who use an electric powered turbine for drag racing. that is in itself a different subject altogether, as the battery system they use is independant of the car's alternator
the e-ram ones do work but 300 to 400 dollars for 1 or 2 psi is dumb. the other ones one bay are garbage. they sell legit superchargers on ebay. ati and stuff like that. get one from a mustang or for a mustang very easy to work with and if it has ceramic bearings it will last a long time.
Turbo is the only way to go my friend. I suggest you pick up this book called "Maximum Boost" by Corky Bell from amazon.com or something. It's the bible to turbo. Its got everything you need to know about turbo and stuff you need to set up a turbo for your car.
Bolt on stuffs are waste of money. Turbo gives you the most power for the money you spent.
I am not saying that these superchargers are worth it, but it is the same mentality of switching from a shaft driven fan or electric fans... it gives you back the power when you want it, but overall is not a more efficient setup...
oh, and SCFM is only one thing that you need to get boost... the other is the built up pressure at that flow rate...
so for a centrifugal pump... you can have 1scfm with super high pressures or 1000's of scfm with barely any pressure... this is why sizing and the belt ratio are important factors in getting ANY performance increase...
