Regional - Pacific Northwest
ID, OR, WA
Through the firewall. Help
Old Dec 12, 2008 | 11:23 PM
Iceman04503's Avatar
Default Through the firewall. Help
So I want to run some wires through my firewall. Does this look like a good place to drill and would i drill through any wires if i drill through here?
Or should I use this? This seems more difficult.
Old Dec 12, 2008 | 11:35 PM
curtislo9's Avatar
For my amp, I didn't drill any holes, I think I used something like in the second picture. But who knows I'm an electrician's nightmare.
Old Dec 12, 2008 | 11:40 PM
Dkfung88's Avatar
second one... theres something like that under the driver side steering wheel... i just popped it off, ran all my wires through that and plugged it back up
Old Dec 13, 2008 | 12:40 AM
BZinn1's Avatar
no need to drill.......behind the glove box is one of the grommets and next to the steering wheel is another......carefully remove the black tape on both sides and push the wire through......retape when complete.....if you drill you will end up with a mess and possible damage to parts.
Old Dec 13, 2008 | 02:59 AM
thanks guys. So the grommet is directly connected to the otherside of the firewall right?
Old Dec 13, 2008 | 03:14 AM
highvoltage1's Avatar
Well thats where i was gonna go through for mine. Didnt realize you can take the tape off and then run it through the center. But hey
Old Dec 13, 2008 | 05:29 AM
BZinn1's Avatar
yeah there is tape on both ends of the grommet,once it is off you can get a lot through there.I got 4 14guage wires and a 0/1 through mine......I never want to push 0/1 through again though.....that was tough.
Old Dec 13, 2008 | 05:44 AM
mattross's Avatar
Alright here is what I do. I have an old arrow shaft that I cut down to 6" and I tape my wire with electrical tape to one end and push the other end through one of the rubber grommets (which ever side of the firewall you choose). It's easy to see, push through, and easy to pull from inside. So in closing go to a sporting goods store and find the cheapest arrow they have and mod it to work for you.
Old Dec 13, 2008 | 05:48 AM
BZinn1's Avatar
plastic coat hanger works good too cut down.
Old Dec 13, 2008 | 06:03 AM
Nastos's Avatar
you can do like this civici saw and run it out the hood and tape it to th side of the winshield and throught hte sun roof or passenger side window
Old Dec 13, 2008 | 06:04 AM
BZinn1's Avatar
LOL.........cuban wiring......at its finest.
Old Dec 13, 2008 | 06:16 AM
TruAmbitionz's Avatar
Tada
Old Dec 13, 2008 | 06:27 AM
808tC's Avatar
yes...thats where I ran my wiring....its gonna come out behind the glovebox.....to put it through the grommet, just tape your wire onto a long skinny screw driver and poke it through the grommet. then go on the other side and feel for the screw driver and take out the tape and pull the wire through.. TADA!
Old Dec 13, 2008 | 06:28 AM
Nastos's Avatar
yeah... but uhhh where that goin to over the valve cover lol
Old Dec 13, 2008 | 07:18 AM
I like the sunroof idea.jk. I want to run it to the driver side because I have switches I want to connect it to. But the arrow idea sounds good. So there's tape on both side of the grommet?
Old Dec 13, 2008 | 05:59 PM
BZinn1's Avatar
If you go from the passenger side you will have to pull off the backing panel on the firewall....it is held on withthe two white plugs. Next cut small holes in it to run zip ties through and zip tie the wire to the piece then remount it to car ....nice and neat and wire all hidden.
Old Dec 13, 2008 | 07:20 PM
Thats too much work man.
Old Dec 13, 2008 | 07:36 PM
BZinn1's Avatar
Well then go through the one on the drivers side......it is much easier and you dont end up needing 6 extra feet of wire.
Old Dec 14, 2008 | 01:02 AM
Yeah doug and David showed me where to go today.
Old Dec 14, 2008 | 02:24 AM
BZinn1's Avatar
see it is easier than you thought huh.........lol
cars are a scarey thing till you tear them apart 100 times.
