odd experience at the pump today.
this is the second time this happens, the first was no where near as bad.
it was time to fill up, i pull into shell to get my regular dose of vpower 93 octane. i turn the car off, fill it up, close gas cap, get back into the car turn on electronics / fuel pump etc. let it cycle then i turn it on. after i filled the gas tank up my idle goes out of wack, jumping up and down continuasly trying very hard to stall unless i give it gas, and when i give it gas theres a major throttle delay, it stalls. i turn it back on and begin to get it moving thinking it just needs some air. as it drives i notice once again a major loss in throttle response, it feels as if the car is in one major lurchy laggy limp mode. i come to a stop and once again am forced to fight the idle untl i just give up and let it die. i turn it back on and bam the idles beutiful and the car is back to normal....it makes no sense this is only after i fill up at the gas station.
what are your air/fuels lookin like when its doing that? super rich? super lean?
mine did it once, same exact situation. It was very very lean at idle 18-20 af/r so i dumped some more fuel in on the idle cells and it never happened again, not sure what caused it tho.
ima fool and im not running a a/f............gota get1 but im sure its overly rich iv been dealing w/ a fuel dump at idle for quite some time now. has somthing to do w/ my tune & 3''intake.
yea toyota tech says your ecu is fried and your motor will be in about a week,
no no just kidding, yea might i ask that u remove the maf flip it upside down so u can see into it look for something stuck in it that u didnt clean out i cleaned my maf three times before i realized something was stuck in between the plastic and the metal sensor
^^haha that cat must be from china then.. cause as soon as it heard the guy in back of him with the camera.. he... gave.... him... the... LOOK....................................................................
