Stock rods
Old Dec 22, 2008 | 04:08 PM
thendawg's Avatar
Default Stock rods
Just wondering what the stock rods are good for power wise, i know ive seen people run upwards of 300whp on stock internals so im just curious. I have a serious piston ring issue (massive blowby) and looks like ill be getting another full longblock to play with, id love to do a full build - pistons, rods, and the works but unfortunately just dont have the coin right now - so if i have a set of factory rods in good shape think they would hold up ok at 240-250whp? I do plan on replacing the pistons with something a little lower compression - 8.8:1 - making it a little more boost friendly, and of cours eill; be replacing all bearings, etc to freshen up the motor - just unfortunately dont have another $400-500 to shell out on rods - and especially when it seems the factory rods would do fine at that level of power - and for those who say ill want to make more later so doit now - the simple fact is i cant lol - its an auto tranny and i DEFINATELY dont have the budget to build the tranny SO this car will def not be seeing over 240 ish whp - if i want something faster ill be buying a diff car.
Old Dec 22, 2008 | 04:49 PM
yamaha16bw's Avatar
340whp and stock rods right now for almost 2 years.
Old Dec 22, 2008 | 04:56 PM
ippskidder's Avatar
1UP Crew
Default Re: Stock rods
You're definitely fine for those power levels.
Old Dec 22, 2008 | 05:12 PM
thendawg's Avatar
Thats kinda what im thinking Ill at least be doing the pistons and going with some better bearings - gotta feel like i improved something lol I think the lower compression pistons will make things a tad more reliable in the long run
Old Dec 22, 2008 | 05:20 PM
ippskidder's Avatar
1UP Crew
i'd go this route:
cp pistons (low compression)
k1 rods (no need to notch the crank)
acl rod bearings (from ptuning.com)
cometic headgasket
arp head studs (from ptuning.com)
Old Dec 22, 2008 | 06:09 PM
m6ar2cel6oTC's Avatar
Originally Posted by ippskidder
i'd go this route:
cometic headgasket
couldnt have said it any better.
Old Dec 22, 2008 | 06:12 PM
RSracer's Avatar
get the ARP main bolt studs from ptuning.com as well
Old Dec 22, 2008 | 06:48 PM
thendawg's Avatar
So yea im def going with arp head studs and main studs - as for rods - ill prolly end up staying with stock - technically i should just rebuild the motor to stock - considering the stock motor should take my measily 250whp just fine but i may as well go ahead with the pistons as lowering the compression will help make it a little more reliable in the long run with boost.
Old Dec 23, 2008 | 12:11 AM
crush02342002's Avatar
im at 292hp but i havnt been on that for very long sooo take it for a grain of salt i guess.......im trying to get a sort of game plan togather aswell for beefing up my engine. id like to hear how your engine quest goes.......good luck bro
Old Dec 23, 2008 | 12:24 AM
Syldrin's Avatar
i don't suggest lowering the compression unless you're throwing some massive boost at itm, 250whp is a joke for the tc as it is. don't waste the money put it aside and do it right the first time.
Old Dec 23, 2008 | 03:42 AM
thendawg's Avatar
So ill prob be doin rods too Dont feel like dealing with not knowing the true condition of the stock rods id be using - and i sure as hell wont e paying for new stock rods lol - waste of money - so im looking at the k1s - anyone know the best deal on them?? Ive been checking out importperformanceparts.net but the idiots say theyll be out of the shop until jan 5th
Old Dec 23, 2008 | 03:44 AM
thendawg's Avatar
Oh and as for waiting - thats not really a consideration that can be made here - motor has SERIOUS blowby and i dont want to drive it further like this - also had some spontaneous oil pressure drops when driving - could be as simple as the oil pump but i doubt it - ill still be replacing the oil pump when doing the build.
Old Dec 23, 2008 | 03:48 AM
thendawg's Avatar
Unfortunately as for power wise - im kinda stuck at that limit unless i wanna do a 5 spd swap or uild the tranny neither or which i plan on doing - EVER
Old Dec 23, 2008 | 02:55 PM
ippskidder's Avatar
1UP Crew
Ok n00b question.
Where exactly are the main bolt studs located????
Old Dec 23, 2008 | 03:45 PM
Guest
Guest
Posts: n/a
Ok n00b question.
The main studs are the fasteners that hold the crankshaft's main bearing caps to the block.
MrC
Old Dec 23, 2008 | 03:55 PM
SoFloTC's Avatar
so ur doing some internals on an auto to push no more than 240whp? let me just ask... whats the point of that? our internals will last a long time on 240whp.. and before doing any engine work i would look into how to take best care of your tranny.. seeing my old tranny went in 8k miles at 242 wheel...
Old Dec 23, 2008 | 03:57 PM
ScionGT35R's Avatar
Ok n00b question.
Those are the bolts that holds your license plate on place!
Sorry. I can't just let it past.
Old Dec 23, 2008 | 07:26 PM
Syldrin's Avatar
you may as well just replace your rings and call it good. save the money for something else. you would seriously bre ____ing that money away if you dont plan on swapping your tranny or having it built. how about this. build your motor then trade me :p
Old Dec 23, 2008 | 09:17 PM
SoFloTC's Avatar
honestly ur money is better in just swapping ur tranny than building ur block. put new rings i and do a tranny swap and run 8-10 psi daily and ur good to go.
Old Dec 23, 2008 | 09:25 PM
thendawg's Avatar
Unfortunately i have a gut feeling the damage goes farther than just rings - well know for sure once i get it torn down fri or sat. If i have to replace pistons or rods though i just dont see any since in buying stock components for it - that seems like id really be wasting my money to tear it down and replace with stock components :/ when i could spend a little bit more and go with a better set of pistons and rods - probably giving myself a little better safety blanket at the levels ill be running - and shh to whoever was _____ing that guy out for not knowing what main bolt studs are - not everyone knows internal engine components like the back of their hand.
