Shimming the S/C Pulley
Old Dec 22, 2008 | 06:31 PM
jrzimm612's Avatar
Default Shimming the S/C Pulley
Hey everyone, I'm having a bit of squealing from my new SC 9.5 pulley and gates belt. I checked the alignment of the belt while its running and the belt is right on the outside edge of the front idler pulley and actually off the inside edge of the rear idler pulley. If I shim the pulley out more I'm afraid It will be off the outside edge of the front pulley. Not sure what to do, but I ordered the Shim kit from TRD just in case.
If I spin the engine backwards using a wrench the belt stays in perfect alignment. But when it spins forward the belt coming from the power stearing pulley in the rear wants to pull itself off of the inside edge of the rear idler pulley.
Does this sound typical or is somthing screwy with that power stearing pulley?
BTW the belt is properly seated on all ribbed pulleys.
Old Dec 22, 2008 | 07:36 PM
GammaTNT's Avatar
does your belt look like that? sticking out of the idle pulley
My idle pulley was bad, i got it replace.
Old Dec 22, 2008 | 08:12 PM
jrzimm612's Avatar
Hmm, that looks just like mine only, the exact opposite. What was wrong with your pulley and how much was the replacement part? Thanks for your help and the picture!
Old Dec 22, 2008 | 09:20 PM
GammaTNT's Avatar
My belt was shredded, and the replacement belt won't stay on after i start up the car.
i think the the pulley cost $160. labor was $60 at a performance shop. They are knowledgeable in turbo area but have no experience in superchargers. They are nice enough to call up TRD, and found out it is a common problem in tc's supercharger.
I am not really sure what is wrong with the pulley, but my guess would be bad bearing inside.
Old Dec 22, 2008 | 09:36 PM
jrzimm612's Avatar
$160? for a freakin Idler pulley?!
Did that fix the problem now?
Old Dec 22, 2008 | 11:21 PM
GammaTNT's Avatar
i have no problem now. the pulley was replaced on Feb. 2008
The bearing inside my supercharger was replaced too, you can read about it here
https://www.scionlife.com/forums/vie...uning&&start=0
Old Dec 23, 2008 | 12:57 AM
sonofabeoitch's Avatar
trying switching the idler pulley's. front to back, back to front.
Old Dec 23, 2008 | 01:47 AM
jrzimm612's Avatar
Thats exactly what I'm going to do. Hopefully the front one is still fine, and if the back one is going bad at least it can't cause a huge problem up front because of the tight space between it and the alternator.
Great Idea Thanks!
BTW will I be able to tell if the bearing is going bad by hand turning it without the belt on? Will it wobble more etc?
Should I even waist my time with the shims if I'm allready on the outside of the front pulley?
Now if only it wasn't -5 degrees out...
Old Dec 24, 2008 | 08:27 AM
gompka's Avatar
Great Idea Thanks!
Maybe, if the pulley moves up and down or in and out your bearings and/or shaft is dead.
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
xjleitex15
Aug 18, 2015 01:23 AM
xjleitex15
Aug 17, 2015 12:09 AM
gqdabien
Jul 30, 2015 07:04 PM
