Twin turbo?
Old Dec 24, 2008 | 06:49 AM
Iceman04503's Avatar
Default Twin turbo?
I tried searching but it came up with alot of single turbo forums. So has anyone twin turboed a tC or do they just go with one giant turbo? Whats the biggest turbo someone put on their tC and it not being drag car? Can the tC engine handle a twin turbo? If you got pics please post them. Thanks
Old Dec 24, 2008 | 07:28 AM
XIEmperorIX's Avatar
no
Old Dec 24, 2008 | 08:21 AM
tcCALI's Avatar
Old Dec 24, 2008 | 08:39 AM
Ace83's Avatar
Ronin Scion
no will not benefit.. they are at least for 6 cylinders and bigger displacement cars
Old Dec 24, 2008 | 09:21 AM
Then whats the biggest turbo?
Old Dec 24, 2008 | 09:23 AM
Ace83's Avatar
Ronin Scion
depends on your build.. what is you goal? bigger isnt always better..
Old Dec 24, 2008 | 11:15 AM
Eltaco's Avatar
Twin turbo on a large displacement 4 cylinder would have problems spooling. I was actually thinking a twin turbo setup like on the '80s model GPZ's might work, but the tC motor wouldn't be able to turn the RPM's that a 750cc would. Just a random thought from me, since I am not turbo knowledgeable.
Old Dec 24, 2008 | 04:30 PM
yellowxhoodie's Avatar
twin turbo setups are usually ineffective, especially on 4 cylinders. even supra guy swap out the factory TT in favor of a larger single turbo, you can get way more power out of it.
Old Dec 24, 2008 | 04:35 PM
^ that and single turbo setups are easier to work on.
the smaller turbo on an FD RX7 is one of the weak links..that turbo goes out frequently and is a PITA to even get to. I think you have to drop the motor just to get to it
Old Dec 24, 2008 | 04:39 PM
limptc's Avatar
not all true. twin turbo can serve a purpose on small displacement 4 bangers. turbo lag is a huge problem most 4 bangers suffer from big turbos. having a smaller turbo that spools up incredibly easy will obviously help with turbo lag on the big one. yes it's a little ridiculous and isn't seen often at all.
iceman: you need to do a lot more research on turbos dude. possibly read this: http://search.barnesandnoble.com/Max.../9780837601601 your questions scream noob sorry.
Old Dec 24, 2008 | 05:33 PM
yeah I am a noob I know nothing about turbos that why I ask.
Old Dec 24, 2008 | 06:37 PM
AlanW's Avatar
If you don't want it to be a drag car and rather something that you'll just drive to the track on weekends, I wouldn't suggest getting a huge turbo. True that you'll probably hit a better power range easier but you'll probably be slower around a track because of the increased turbo lag. The power will be basically unusable in a typical condition, like in a city. I really wouldn't think anything over 350whp would be driveable as a DD in a city because it IS FWD... You can reach 350 with the kits that are selling right now, Turbo Toyotas, Dezod, etc.
Old Dec 24, 2008 | 06:38 PM
StreetStarsTc's Avatar
no.....
Old Dec 24, 2008 | 07:28 PM
Most of the kit i'm seeing is 270-300. If I want more HP then I have to go with a larger turbo than the ones they are selling?
Old Dec 24, 2008 | 07:34 PM
geo46_2's Avatar
Old Dec 24, 2008 | 08:04 PM
Originally Posted by geo46_2
Yeah that doesn't help very much. If you don't have anything to say then don't post.
Old Dec 24, 2008 | 08:11 PM
shupes31's Avatar
word. good luck on your quest for boost.
Old Dec 24, 2008 | 08:18 PM
davedavetC's Avatar
wouldnt the turbo system youre thinkin of be a sequential turbo set up? where the smaller turbo is in direct line with the bigger turbo so that it spools the bigger one up faster? where as in a twin turbo set up there are 2 spooling to create power together.
Old Dec 24, 2008 | 08:47 PM
limptc's Avatar
well yah, isn't that what the op was going for? or did he mean one turbo for 2 cylinders?
Old Dec 24, 2008 | 08:48 PM
davedavetC's Avatar
from the sound of it looked like he was trying to go for one turbo for 2 cylinders
