Custom Oil container for Turbo ???
Old Dec 27, 2008 | 05:53 PM
ValenciaS's Avatar
Default Custom Oil container for Turbo ???
This is just a thought guys let me try to explain, since you have to tap the oil pan for the turbo, I was thinking if you could make a separate container and mount it somewhere safe in the engine and have that be the oil source for the turbo. Can this be done if so would it be safe ?
Old Dec 27, 2008 | 05:54 PM
nebster's Avatar
yeah its called a dry sump system.
Old Dec 27, 2008 | 05:56 PM
ValenciaS's Avatar
hey neb , would you suggest it , also where could i purchase this ?
Old Dec 27, 2008 | 05:57 PM
nebster's Avatar
there is no point in doing it unless you have a full blown race setup
oh and they're expensive. VERY expensive.
so no
Old Dec 27, 2008 | 05:58 PM
ValenciaS's Avatar
oh ok just woundering , Ill pass lol, pretap here i come
Old Dec 27, 2008 | 06:01 PM
nebster's Avatar
if you have a spare 5k to drop and have another driving car then sure go for it.
Old Dec 27, 2008 | 06:14 PM
cburglb34's Avatar
dont go too far, u can fab up your own dry sump for cheap u can get a tank to hold about 2qts of qoil and two pumps.. one for feedind the oil at around 130psi and one for returning the oil to the tank at gravitational pull...to be really honest u only need a pump for the feed if u have the can placed under the turbo
Old Dec 27, 2008 | 06:26 PM
ValenciaS's Avatar
Negative , ill pass lol
Old Dec 27, 2008 | 09:19 PM
TurboToyotas's Avatar
Old Dec 27, 2008 | 09:22 PM
nebster's Avatar
i'm not sure if you're being sarcastic or not.
doesn't the engine need oil to work properly?
Old Dec 27, 2008 | 10:50 PM
Old Dec 27, 2008 | 11:24 PM
purplenitroustc's Avatar
Of course the engine does...
but I was referring to the turbo. Water cools better than the oil.
The only issue with a "wet" center section is for road racers as they are not allowed to run actual coolant at the tracks. They have to run 100% water.
otherwise for a street car its ideal, the turbo get lubricated by the actual coolant (same way the oil works)
And water lines are allot easier to install than oil lines.
Regards-
Todd
good idea
how much would it cost to convert an oil only cooled turbo to a water only cooled turbo
Old Dec 28, 2008 | 12:48 AM
good idea
Can be changed out when ordering a new turbo. All manufacturers offer it.
Otherwise you would purchase a new "wet" chra and use your old housings.(sell your old oil cooled/lubed chra)
Regards-
Todd
Old Dec 28, 2008 | 01:46 AM
Ace83's Avatar
Ronin Scion
todd the wet chra you are talking about is a different type housing from the the gt turbo? i remember theirs two types of watercooled turbo this would be the other?
Old Dec 28, 2008 | 02:04 AM
Old Dec 28, 2008 | 02:34 AM
Ace83's Avatar
Ronin Scion
true on that though, i've been told by few people they didnt run any water lines on their gt turbo and didnt have an issue.. but as i see it they have their car always in the garage while i drive my car everyday so no point not doing it the right way..
Old Dec 28, 2008 | 05:39 AM
good idea
Regards-
Todd
where can I purchase one? I have a Garrett 60-1
Brammi
Nov 13, 2016 03:46 AM
my06tc
Jun 25, 2015 12:18 AM
tom0613
Mar 7, 2015 05:59 PM
CONCRETETC
Feb 9, 2015 08:05 PM
